never had to pay a windows tax as ive always had access to VLK licences thru my employer
thing is though mate, microsoft is banned in my house. even my router and gps are free from microsoft software. lol.
and if i could buy an all in one monitor/case solution in parts you dont think i would do that?
got any links to where i can buy an apple monitor case and the componants to suit?
Theres no reason why you cant build a powerful intel x86 box and install macos X. just means you wont have the fancy mac decor (which is overrated imho). Fair enough to not like the way MS does some of their stuff, but I think win7 has come a long way and is actually quite nice to use - I'll never ban anything as long as it serves a purpose, however I do prefer linux for many server related daemons, that said, linux is only free if your time has no value. never liked macos x either...
never heard of a router running windows. people must be masochistic these days. DD-WRT does me fine.
-D
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
    • Genuine GTR seat? There are none you would actually want for <$3k a pair.
