SSD any news on price drops ??
http://www.pccasegear.com/index.php?main_p...oducts_id=10933
$329 on a 60gb, thats a fair bit cheaper than what it was 3 months ago. I'll wait another 6 months till my beta version of w7 expires and then I'll get the SSD and w7 home
-D
yeah still a tad too rich for me
i would rather a 5850 for around that money than a bit quicker hdd
depends on what your aim is. if you're not gaming, an SSD makes a hell of a lot of difference
my eee 901 now boots faster than my i7 920 - the 901 has 2gigs, the i7 has 12 gigs... but the difference between the hdd's is a good minute, and thats with the inferior hardware booting off the ssd and winning...
wait till they come down to $200 for 60gigs, give it 6 months or so :D
-D
Yes and No...Yes to Playing MW2, No to playing on PS3, shall be on PC.
:thumbsup:
Shall also be playing on pc, along with working on patching my ... "disabled" copy of mw2 so it has multi again.
Just found out about this, sounds awesome: http://www.moddb.com/mods/gta-united
  • 3 weeks later...
What are your steam names for CODmw2 ? Real nice game.
Also damo. Add 'barik' for the ps3. My mates account. He is pro, but Ill head over sometimes and play. Im hopeless on ps3
Steam account name is :Xer0c00l
I dont play games very often any more, and when i do, mostly co-op.
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
    • Plug and play. Need a tune. It's a PowerFC, same as any other PFC, just not needing an AFM.
    • Genuine GTR seat? There are none you would actually want for <$3k a pair.
