SSD any news on price drops ??
http://www.pccasegear.com/index.php?main_p...oducts_id=10933
$329 on a 60gb, thats a fair bit cheaper than what it was 3 months ago. I'll wait another 6 months till my beta version of w7 expires and then I'll get the SSD and w7 home
-D
yeah still a tad too rich for me
i would rather a 5850 for around that money than a bit quicker hdd
depends on what your aim is. if you're not gaming, an SSD makes a hell of a lot of difference
my eee 901 now boots faster than my i7 920 - the 901 has 2gigs, the i7 has 12 gigs... but the difference between the hdd's is a good minute, and thats with the inferior hardware booting off the ssd and winning...
wait till they come down to $200 for 60gigs, give it 6 months or so :D
-D
Yes and No...Yes to Playing MW2, No to playing on PS3, shall be on PC.
:thumbsup:
Shall also be playing on pc, along with working on patching my ... "disabled" copy of mw2 so it has multi again.
Just found out about this, sounds awesome: http://www.moddb.com/mods/gta-united
  • 3 weeks later...
What are your steam names for CODmw2 ? Real nice game.
Also damo. Add 'barik' for the ps3. My mates account. He is pro, but Ill head over sometimes and play. Im hopeless on ps3
Steam account name is :Xer0c00l
I dont play games very often any more, and when i do, mostly co-op.
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
