Computer Jargon
Madaz
do you have an shdsl service? that is some pretty epic speed
SHDSL is only 2.3Mbps (with one pair anyway), you'd have to multiplex a number of them to get more - and even that wouldn't hit 50Mbps ...
  • 4 weeks later...
Most 4870 cards are a bit noisy, trying to keep my system as quiet as possible. 2 4870's also give more performance than one 5870 so worth the relatively small investment
5850 would be good enough by itself, but don't really want to spend that much. 4800 & 5800 series cards are also not compatible:
http://game.amd.com/us-en/content/images/c...combo_chart.jpg
didnt realise they weren't compatible
trying to find a review of the 5870 against a CF 4870 might have to look later
what type of motherboard have you got i did read that if its a 16x/4x you might be better off with 1x 5870 but there like $600
Running a Core i7 920 clocked at 3.2GHz on a Gigabyte EX58-UD5 motherboard. Can run 2 cards at full 16x speed.
If I end up making the jump to a 5870 it won't be until they have halved in price. Not going to happen for a while though, especially since Nvidia is yet to release their competitor. I have a feeling they've been caught with their pants down & weren't expecting ATi to improve as much as it has in the last couple years. Either that or they're looking to make something that will totally dominate, though they may run out of development funds if they don't look out.....
imo ATi will bring a 5990 out soon after the fermi to try and keep a wrangle hold on the market may work it may not i dont know much about Nvidia as they dont hold my interest
that board is pretty nice 3 way CrossfireX or SLI 2 @ 16x and 1 @ 8x
so its the **70 series or nothing you wouldnt consider 5850's i run 2x 4850's in a OC Q6600 and score 18k in 3dmark 06
>>3d mark 06 18916<<
back when i tried a 7800GTX it didnt perform up to the hype and i stuck with ATi
>>3dmark 06 7800gtx 4069<<
>>3dmark 06 x1900xtx 4990<<
Actually for 3 way SLI it works out to be 16x8x8. It splits the second lot of 16 lanes over the lower 2 cards in 3 way SLI. Completely useless though unless you happen to own a super expensive hi-res +30 inch monitor. 2 slots is pleanty :cheers:
2x 5850's would be awsome, but still rather pricey at the moment & a bit overkill IMO. If I can get a second one of these cards it will be by far the best bang for my buck at the moment, just going to have to keep an eye out.
2x 4850's should see some pretty good performance, probably starting to push the limit of your CPU.
yeah 1ghz OC is enough
i didnt read that mobo as that but you would know i only read the stats page from gigabyte
yeah i think 2x 5850 is like one 5870 prolly a little more for the 2x 5850 dont look @ prices or ill want a new system and mine is good enough
    • Brand new r34 gtt box
    • What is the go to gearbox these days for a RWD RB? Back in the day VG TT boxes were cheap and strong. Seems they are as expensive as an RB25 box these days. What are the options without remortgaging the house?
    • Define "Nissan big brakes". You just mean standard R34 4 pots? And...it's not even the offset you need to worry about. It's really a detail of how much clearance there is between the caliper and the back of the spoke/face, which is affected more by the design of the spoke than it is by the offset. If you think about it....take any wheel, say a 19x8 that does fit and clears the caliper. Then add or subtract an inch of wheel on the outside, without changing anything else. You have changed the offset by half an inch, but not changed the clearance situation at all. Same for if you add or subtract an inch from the inside edge. The way for you to work this out is to take a wheel off the car, grab a straight edge and a ruler or two, and start to measure the distances from the wheel mounting face on the hub to the outer face of the caliper, and the outer diameter (that faces the barrel of the wheel) of the caliper. Armed with these dimensions and any other measurement that grabs your fancy while you are there, you can then go to the seller of the wheels and do the reverse measurements from the wheel's mounting face and see if there will be clearance to the caliper. There really should be. I have 17x8 RPF1s +35 clearing the caliper face by a finger tip. Those wheels do have pretty thin spokes with some curvature.... but then so do most wheels to suit Jap cars.
    • So I’ve got a r34 sedan that I managed to get green stickered, meaning I need to go through government approved wof station for my car to be allowed back on the road for some reason my car is certed for 19x8 rims.. I need these wheels  does anyone know what offset will be fine to clear Nissan big brakes? I saw 35et for sale near me, I can’t drive the car to test fit or risk being fined ..   I searched heaps online couldn’t find anywhere..
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
