ok i give up and need some help getting my website up and running properly and the email account as well :-(
so if anyone knows anything about PO3 emails and getting domain names up and running more than happy for some help
(luke i know your technically minded and want to see my place so win win :nyaanyaa: )
are you hosting the domain and mail services yourself or paying a third party to do it for you?
i've setup domains and emails on linux and windows servers before, if you're doing the 'host it yourself' route.
the other way is easier, just call up the isp/host and tell them what you want
-D
O.K guys need some advice if I can. Looking at going into a "rent to buy" plan at Jb's, Harvey Norman or Radio rentals to get a laptop, not looking for anything WOW as there wont be any gaming and graffic work being done on it. What could you reconmend I look into? P.s not a MAC fan at all
Look at getting an Asus Laptop, stay away from Sony Vaio. I wouldn't recommend "rent to buy" for a few reasons;
1. you pay more then the laptop is worth
2. getting repairs done under warranty are a pain in the ass
3. If you do go "rent to buy" write down the serial number and model number, as quite often if you take the laptop back for repairs it may get lost/swapped with another customer different laptop.
Only reason I'm looking at getting the laptop and "rent to buy" is so I get a credit rating as I dont have one and will be looking at buying a house soon so figured it will help out with the house loan. Its either that or the 24 months interest free but not sure how that works out. Yeah understand by the end you pay more then they're worth, but that beats the upfront payment of the larger amount and the no credit rating :(
Pretty sure it only counts if you default or fail to pay it off, it will affect you negatively then. If you pay it off on time it won't do shit as far as I know, especially as it is such a tiny amount.
I know this isn't how it works but personally if I saw that someone needed a loan for a laptop and wanted to buy a house it would tell me they suck at saving and hence might also suck at paying off a house.
Just buy a dell off their website, they are so god damn cheap these days, ~$600 for the basic ones which are more than enough power for office work.
Edited by Rolls
It's requesting a line of credit - so it will come up in a credit report.
Mind you - so will applying for a personal loan, or a credit card.
I would have thought applying for a small credit card (and not using it) would have been more beneficial for your credit rating, TBH.
  • 3 weeks later...
Any of you boys tried these before
http://www.netcomm.com.au/netcomm-products/powerline/np204
I just got a pair from MSY and am loving them, had a guts full of wifi for my media pc so these are a good option i think!
I’ve given them a shot before when I needed a temporary LAN. The ones I had (Netgear if I can recall correctly) claimed to run at 200Mbps. I know that’s a theoretical speed however based on my tests I could only ever achieve 30-35Mbps tops which was too slow for my needs. I was expecting at least 50Mbps. Now I have wired the house with CAT6 right through. MUCH better for multiple hi-def streams :D
Anyone had experience with $500 workstation graphics cards? I'm looking to get one for work but have had nothing to do with them before.
Yeah they use geforce quadro's for cad at my work. Pretty good cards for rendering 3d models in complex detail. Not good for gaming ;P
-D
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
