Yeah they use geforce quadro's for cad at my work. Pretty good cards for rendering 3d models in complex detail. Not good for gaming ;P
-D
Not to mention pricey, last time I looked...about 6 months ago, they were around the $1k mark or higher.
-D
What CAD systems are they using?
It will be used for predominantly CAM applications, Edgecam to be specific. With a bit of CATIA and SolidWorks thrown in for good measure. Tool-path verification will be what i need the graphics power for. Unless it is coded to support some GPU computing, which I doubt.
Is it worth going for a workstation card even if the program isn't specifically supported with drivers? Or would I be better off spending the same coin on a gaming card which will have more brute power, however not as fine tuned?
anyone got a decent computer for sale cheap ??
i have a barebones chassis (case + motherboard, u would have to get the rest) in my cupboard that i'd happily part with. had big plans but went in another direction.
lemme kno if u want more details /pics etc
Heaps. Wonderware, Autocad, Altium Designer, etc...
Depends on the software - I'd check with the manufacturer. No point spending $1k on a card that the software cant use.
-D
500 just the tower i got monitior wanted for some vidoe editing nothin spectacular and just crusing the net
glad to see you bought only what you needed
many people get sucked in
count yourself as not one of them ;)
-D
I asked Adam a few weeks ago to change my Internet Plan to their new plans - AdamBasicChoice 100GB, which is up to 20Mbps.
So my account rolled over the other day, and I hadn't received my extra speed - was a little pissed, so I sent them an email, and they replied saying it was going to take 3-5 days, as the wholesaler still had to apply my upgrade.
Well, I got home today from Balgowan, checked my speed, and I am rather happy with it :)
Had torrents going at the time, but I am not going to complain.
If your with Adam make sure you up your connection profile. I've got a SNR of 6 and run stable on their second to fastest profile. I sure noticed the difference over standard.
I have no idea how to do that, but with my modem - Billion 7300GRA with Autodetect settings, I get this
You've also got to watch the error correction, speed and snr often look good on higher profiles but a good chunk of speed can be lost to correction on not so good lines.
If you're on an Adam dslam, jump on the members page and go to 'View Performance Profile'
Nope, don't have that option. Most likely as I am on ADSL not on ADSL2+, even though my modem is using the ADSL2+ protocol to sync...meh, I am happy with the results - downloaded 1.4gb in 10-20min :)
Sure it's not ADSL2+ over a telstra dslam?
"ADSL" will get you 8mbit/1 and "ADSL over POTS G.992.1" 12mbit/1.3 under perfect line conditions.
Adam can still tweak the line profile, but you've got to call up to get it done.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
