Yeah I run my Quad core AMD 965 @ 3.825Ghz all day every day (it was 3.4Ghz stock) - but I have taken it to 4.3Ghz (it is water cooled) ... temps went a bit high when playing Crysis 2 at full res though, so turned it down. TBH the performance benefit of 4.3Ghz over 3.825Ghz is negligible anyhow. And my dual 64Gb SSDs are not a choking point either.
I've sent my OCZ revodrive back. Kept corrupting the partition every time it would shut down. Something seriously wrong there. Hopefully they give me an upgrade once its verified faulty
-D
Wow that sucks Ben. I seriously thought about buying one for a decent clients machine I was building around that time, but ended up erring on the side of caution. The lack of TRIM support had me worried.
Hope yours gets replaced with the upgraded version with TRIM and idle garbage collection support.
I had a 200Gb A-Ram SSD with Sandforce Controller that shit itself after 10 mths in my office machine....................they've got a long way to go with these new drives cause I've never had a SATA or even an Eide drive die on me since Win95 1st Edition
This one doesn't have anything to do with TRIM or the garbage collection
Rather, its still writing data when the motherboard powers down - either the drive or Win7's handling of the shutdown procedure is bunk.
The x2 drives are a significant improvement - theyre also significantly more expensive. I doubt I'll be given one of those
-D
You don't want to stripe, if one goes you'll lose both, doubling your chance of failure. Mirror with 2 disks or RAID5 with three disks is good for backups, both options have 1 disk of redundancy with RAID5 giving a performance increase. Raid0 is only for going fast and for anything you don't want to keep.
If your data is really important, get a docking station for a HDD and back up onto a 2TB drive and then unplug it and put it in your safe. Raid is good if a disk dies but if you get a virus or accidentally delete something you're still screwed. Having the drive unplugged also protects you from stuff like power surges, theft and system malfunction.
striping is fine for operating system data, esp when you have the MBTF of a modern SSD
Eg Revodrives are internally raid 0 to get their 540MB per second reads
-D
All good points, personally what I would do is if you don't have a huge amount of important data to back up is do this.
Stripe 2 or 3 High performance disks together, and then have another 2Tb backup drive. Now you could mirror to the 2TB, but most the time half your data you don't care about, so do what I do and every night backup all your documents and settings folder, desktop, my docs and any other important data etc. That way if you lose a disk you just format and copy your data back. If you can afford it do a mirror as well but often it is unnecessary. I don't run a stripe, but I do the same thing in principle with my drives.
I have about 5 disks, I backup everything important from one disk to another disk each night, assuming I only get one disk failing at any time, I don't lose any data. I also backup to dropbox, and then via dropbox to my work PC.
Edited by Rolls
  • 1 month later...
hey guys, good to see this thread is somewhat still active.
Kralster get back from E3 trip? How was it, I watched it live and thinking about going there next year.
And have any of you guys heard about the new tech scheduled for later this year from AMD and ATI? I am building a PC around october and still unsure whether to grab a 590 or 2x580s and have not heard anything ATI has to offer.
That guy is still around? :blink:
    • I just bought the Nexus S3 for my gtt, haven’t installed it yet as I’m collecting parts to do everything at once…so far spent $14,000 The Nexus is nearly future proof
    • Honda's hybrid system can be easily scaled up to PHEVs. Series hybrid at low speeds, at higher speeds the engine directly drives the wheels but there can still be some power bled off to charge the battery + the electric motor can still provide parallel assistance too. It's really only a question of will at that point. Toyota's PHEVs are selling incredibly well at the moment because of the flexibility. You can run on EV mode when it makes sense, but if you're planning on doing a long highway drive you can still fire up the gas engine and not have to worry about dealing with the rather miserable state of public charging infrastructure.
    • Only reason to keep a MAF on your RB25 is to be able to easily calculate true VE if you know what the factory voltage curve represents in grams per second of flow. Also allows you to do things like pull the original OEM ignition + AFR target tables and use those as a starting point for your base map. Once you're well and truly done tuning though there's no need to retain the MAF.
    • Do you think they'll merge there performance divisions and we'll end up HoMo?
    • Very true, if buying new, I would not get an PP either. Minimum is an Elite 2500, which is also considered outdated. Get something that supports DBW, delete that cable throttle. Best thing I've ever done to the Skyline, next best is refreshing the A/C with a new condenser. It's cold, but not as cold as modern car, but colder than most 90s JDM shit boxes imported into Australia.
