damn.. cant find a blutooth adaptop anywhere for obd1
would this work to relay the signals to the android app?
OBD connector to usb - usb to usb adapter - then your usb data cable to phone
or something like this: http://www.ebay.com.au/itm/High-Quality-micro-USB-USB-Female-Cable-USB-OTG-N900-/190507971718?pt=AU_MobilePhoneAccessories&hash=item2c5b28f486
not sure you can but why do you want to? you can get it to delete the email but not mark as read
personally myself i use windows live mail for hotmail and sort emails by conversation to all duplicate subject email get put into a bank then i can select the last email from that conversation and visit thread the right click and select all press delete and then its all good
Haven't justified buying a SSD yet given the amount I don't use the computer.
So I picked up a $100 Seagate Momentus XT 500gb. Damn its made an impressive difference to how windows boots, shuts down and generally runs. Noticeably smoother.
Recommended for those who'd rather sink $$ in to something else than a computer but want a smoother running less crunching/clunky computer. :) All though an extra $100 will grab an SSD these days. :P
Yeah I am going to pick up a couple of Momentus soon too .... I currently have 2 x 64Gb SSDs as my Windows and Program files drives (non-RAIDed), and whilst the speed is great, every time I need to load a file off one of my storage drives the pause is unbearable. It is not a huge pause, but with a hybrid drive I would buy 2 and mirror raid them - that way I could fit my Win7 install, program files and current Torrent data on the 'one' drive, which I think would be significantly faster than my setup is now.
Have you done any read/write tests Joel?
I'm not sure benchmarks are going to show how these drives perform. They only have 4G SSD which the drive stores regularly accessed data. From what I have read all writes go to the mechanical side. So things like random reads etc may not be that great unless they are run several times over. I'll see if I can find the article where I read this.
EDIT: here it is
Edited by Race__24
^^ yeah i half did that upgrade i have a Gigabyte GA-Z68MA-D2H-B3 $139 and a i7 2600k $330 and 8gb of gskill sniper ram 1333 $69
it is a lot more faster to boot into windows now and i only have blue and green WD drives both 7200rpm
i will look into SSD one day just not really sure what route i should take
    • Pay diff/trans workshop to do this.   Nope. Z32 turbo ran R230 with 6 bolt GTR style axles. All other Z32 were R200. Basically same same as other R32 stuff. All were a viscous waste of space.
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
