I'm with Adam as well Andrew with this result........big difference in Ping speed, what's that all about?
I upped the ante to Aggressive mode (ADSL2+) and it upped the ping rate slightly but dropped the download rate..........maybe time of day??
The ping will vary - 2ms is nothing. :D
Distance from the exchange.
My own service connects at a slower speed when connecting with ADSL2+ compared to ADSL1.
However connecting as plain old ADSL2 (without the +) it connects at its fastest.
What you need to do if your modem supports it is place your self on an ADSL2+ standard type profile that aims for an SNR of around 9-10 and then force the modem to connect 'only' in ADSL2 mode.
Doing so will generally provide the quickest connection at a longer line length.
LAN limited :P WOOT :(
bizarrely while my ADSL1+ gets a MAX of 4.5Mb/s on speedtest, sometimes I get download speeds as fast as 600kb/s in UTorrent, when downloading multiple torrents from a good source (like tvtorrents private tracker). I am not sure how I get such good speeds sometimes - yet have NEVER downloaded from the 'normal' internet (even direct from Adam or a pipe) at that 600kb/s.
Supposidly (got spelling) i'm on ADSL2+ with Internode and this is all I get living in Panorama.
Pretty pathetic in my opinion.
Ignorance is bliss.
All bets you are on the ADSL2+ Very High Reliability Profile and haven't changed it since day one. :P
Double check to ensure all devices connected to your phone line are filtered. The modem doesn't require a filter. Run a <3m telephone cable.
The ping will vary - 2ms is nothing. :)
LAN limited :P WOOT :)
Thats quick, dies anyone still use dail up, they were the good old day take a week to down load a pic of a car!!
Now now, before I had ADSL (still on 1, no 2+ here ;) ), I used to download several gigs of anime & movies using good old dial up.
It does take several days or weeks for the 700mbs, & people can't call the house (which isn't really a bad thing, considering all that telemarketing crap I get everyday).
Edited by Mayuri Krab
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
