  • 3 weeks later...
ok if any geeky tech heads are heading to melbourne the 8th of movember you may want to check out Swinburne University for the alien ware launch of Call of Duty world at war lan sound salot of fun :O
http://www.alienware.com.au/party/
taken from GameArena
best quote scrolling through the chit chat
i swear melbourne fking gets all the good **** , when does sydney get stuff like these?.
You guys had a massive parade of people in skimpy outfits just recently. Oh hang on they were all gaylords.... guess that's what you get for living in the gay capital of Australia.
ooooooooooooooooooooooooooooooooooooo
hopefully this installment isnt anything like modern warfare with its amount of online hackers
shall make for interesting LAN competitions
writeoff,
All speedtests really are is in indication of your sync speed. Internode/TPG you should be able to obtain the same sync speed providing the line profile you select targets the same SNR and using the same modem. Some modems connect up a good >1mb quicker.
Typically the ADSL2+ STD profile on internode targets an SNR of 9db. A nice balance between speed/reliability. The Internode highspeed adsl2+ profile targets an SNR of 6db. Still good reliability providing your copper run from the exhaust to the house and internal wiring/filtering etc is all spot on.
I've tweaked mine a little and have the SNR down to 3-4db. Holding stable for 8+days. :)
Well this is Adam internets 8mb plan as were in goolwa, no adsl 2 or 2+ for us here unless we wanna pay ten times the price for Telstra shit service and speed. My girlfriend was also using Second life at the time I did the test which sucks the shit outta my connection.
Edited by Stagstock
ok,
the missus has a computer that we had stashed away in the shed, i pulled it out
a little while ago and plugged him in
shit me, its works, and already has XP installed, its fresh, no files/programmes etc
now, i need to install my optus wireless internet driver, but i cant find it ;)
can i burn it from my lappy and install it on the other comp.?
or does someone have a driver i could possibly borrow?
:P
ok,
:P
copying the program files will not work
i work part time for optus and i know people high up so i can most likely get the software you require ,
the software you require , is it for an OWB ?
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
