In the hope to o/c my E8400 some more (4.4Ghz+ air cooled), I've upgrade my heatsink (Xigmatek HDT-S1283) and case to a full tower (CoolerMaster HAF 932). The case is awesome...it has 3x23cm fans (or supports 7x12cm) + 14cm rear exhaust, also, for when I try my hand at water cooling latter down the track it can support 2 PSU's and 3 fan radiator + 2 fan rad + 1 fan rad = :P:D
hahah awesome Patrick I've been thinking about a 4850 gfx card cause its mid rang bang for buck and i dont have a good enough CPU to even make full use of its power but I'm sure its better than a x1900xtx
thats why u have 2 8600's like me xD
I had 8600gts. not bad.
but the new 9800gt runs cod4 perfect. everything high. high res too.
crysis runs smooth too on high. very happy. and it doesnt cost the world either.
  • 3 weeks later...
I'd doubt they'd release it mid-year....if they were smart it will most likely be closer to the Xmas season plus will give more opportunity for other programmers to make their software compatible.
Yeah I'll prob try it out...good thing Vista has disk-part otherwise loading this for a tri-boot would be a pain.
first impressions of win 7...
u cant set the start menu to the old skool style... have to use the homosexual spec new one. and the aero shake thing is pretty cool.
other than that it seems to me that they have made vista, more "vista" does not wanna let u think for urself
:down:
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
