yeah I have just finished installing Windows 7 and it looks very good for a Beta. I am just wondering though - exactly how is it different to Vista? I have found very few differences except for its speed and stability.
better networking :P
hey i hav live for speed s2 and i am wondering how to make the cars sound good like i hav watched it on youtube and ther are some pretty tuff sounding cars on ther, they use patches or some sh*t i dont kno. I am not very computer smart at all (as u can prob tell lol) so i was wondering if any knos how to do it or could help me cheers jarad
Bishop you can do it with a program called LFSTweak, it lets you change then engines to anything from 4 cylinders to turbocharged V12s, can change tyre size and all sorts, some engines sound f**king gay but some sound awesome, the program only works with the latest version of LFS however.
Another way is to use CSR like they did in the video, this program is harder to use and I don't know if its supported any more, however its worth a shot http://www.lfsforum.net/showthread.php?t=12863
Have a browse around on the LFS forum in the addons section, theres a few mods that allow you to change the blow off valve etc as well.
Its rolls, matts friend btw, if you get stuck hit me up on msn [email protected] catcha
Edited by Rolls
Also, has anyone else got a Wii? I bought Wii Fit for the missus for Xmas (I wasn't being rude - she requested it) and just got a game called Family Ski. Being a snow skier it is a very realistic and highly entertaining game! Thoroughly recommended.
So many people in various forums bag Wii Fit as boring and not worth it, but I have been enjoying it since Xmas - an effective way to get off my ass and do some exercise and have a bit of fun while doing it. I have had many 1.5 hour sessions where I can feel afterward that I have had a decent workout (some of the exercises are absolutely brutal) yet the time flew and was fun. Bizarre - I never though I would get into it - but I have used it much more than Carolyn at this point (but I need to whereas she doesn't lol). I have noticed my fitness and coordination has improved in the short time I have had it, so that is encouraging.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
