imo we need to have an sau lan at arena again
seeing as i missed the last one and the last time i was at arena was for GG arena draft
ya, do it! I am putting on new games like COD5, Red Alert 3 and few other 2008 games on arena's machine now...... :yes:
Yeah Ive got a SPEEDIO novation midi input output external thing. Just want something to run nicely with it.
This speedio thing is 48khz. 24bit sound. etc. Gain controls. input gains etc. phantom gain. Made in the UK
I'm not sure I understand why you need the Creative card at all then....
i almost came to see you last friday johnny but started running out of time to go get my daughter from school
it's alright, we got plenty of time to catch up, dont worry! :banana:
should have arena Left 4 Dead lan up!!! such an intense game! lol
mate, u have no idea how many people play and love that game at arena, especially everyone play in "VS" mode, it's soooo f**ken fun, screaming shouting, crying......umm yeah!!!! let's setup a SAU LAN soon! :banana: L4D FTW!
I got Left 4 Dead here too but havent touched it yet...... purchased and downloaded the Valve Complete Pack and have only played about 10 minutes of Half Life 2 so far - even though I've completed years ago... but this time playing on full settings everything on my new computer :banana:
yeah ok ill organise another one but im thinking we just skip the coffee the 2nd time we tried to do coffee failed
EDIT most of u need to go >>Here<< and uncheck Is daylight saving time in effect? :banana:
make sure to click the button at the bottom change my settings
has anyone here changed to win7?
there is a release candidate available now
http://www.mininova.org/tor/2495642
im thinking of giving it a crack, my install of xp is getting a bit tired and thought i might 'upgrade' rather than reimage. have only played with it in a VM so far
gonna run it as a second OS first in case it has a bad case of gay
Looks as though MS have still been looking at OSX... Vista was a heap of shit not sure it's worth d'loading 7 just yet!
im guessing not. i'll be waiting till it comes out in a final version, then i'll buy an i7 cpu and the rest.... screw vista too, xp works fine in the meantime
-D
    • Regardless, its peace of mind swapping the factory twins for something else. Personally if it was me: Link G4X Additional sensors for engine protection Twins Oil pump mods(maybe throw extension to sump) injectors/Pump Clutch Exhaust Oil Cooler Good pads/suspension Should be good for 3-350kw depending. Granted thats closer to 15k but still.
    • I think you are over thinking it again
    • My R33 never ran more than stock boost but it was unclear whether the turbos would last. Maybe OP's car is less of a question mark but for my stock turbos had over 175k km on them + 25 years of use. That's a very long time to hope nobody has ever accidentally put physical shock through them, no debris in the exhaust gas stream, no boost leaks that could cause the compressor to spin faster than it otherwise should, no oil coking in the journals, no wear scars for any reason, etc. You could pull the turbos and disassemble to inspect/overhaul as needed but for that kind of effort you may as well replace the ceramic turbine with something that can take a bit more abuse no matter what you find in there. Stock boost ceramic turbos really don't make that much power either.
    • A Pillar forward?   The part above I was just looking at was the reo bar, I'd replace it, UNLESS the panel beater is GOOD. From your early photos, it did look like the chassis might be tweaked, or at the very least there was tweaks in radiator support. I'd personally do a new / second hand unmolested reo bar, and drill it, only so I know underneath the pretty painted front bar, there's not a mess of other metal that's been hit and smacked.
    • Yes no yes. Pineapple rings do do a certain amount of subframe "locking up", in that they do add some resistance to lateral movements. But the primary reason they exist is to alter the driveline angle. Depending on how you install them you can either increase or decrease rear traction __ a little bit __ by changing the angle of the lower control arms relative to the car/pinion angle. The thing is, given what they are, how and where they are installed, their lack of engagement with anything in particular, there's a limit to how much benefit they can offer. The GKTech collars put metal into the space in the stock format bushes, thereby limiting how much give they have. The rubber is still there to take up some force, albeit perhaps preloaded a little by having some extra metal jammed up into it, but the increase in stiffness comes from making it so that the stock format bush can't deflect that large bit of rubber over into the space adjacent to it, in any direction. Top AND bottom. Which the pineapples certainly do not do. As I said in my other thread - I'm convinced.
