FF are pretty quick releasing updates to deal with any vulnerabilities compared to IE in the past. Also, if Opera had a bigger market share, I'm pretty sure more vulnerabilities would be found and exploited.
ATM I'm using the latest FF 3.1 beta (default browser) and ocassionaly IE8 which is quite zippy and stable now. Although, I found having dozens of certain Facebook pages open will generally crash any browser.
Haven't looked at the hardware scene for a while and I'm gonna upgrade. For those who are interested in commenting on the components, please do.
The list is as follows.
New PC: Running Windows 7
Intel i7 920 CPU $415 LEADER
SAS 74gb Seagate HDD 15k RPM $318 LEADER
ASUS P6T Deluxe Motherboard $459 MSY
OCZ DDR3 PC3-10666 i7 Edition 6GB $169 PC Case Gear
HIS Hightech Radeon HD4830 512MB $156 PC Case Gear
New Server (from current hardware)
WD Caviar 1TB Black AV x2 $334 MSY
3xSATA Hotswap Bay (2x 5.25" bay) $150 LEADER
Gonna chuck RHEL 6 on the server and run raid1 TB as a filestore and use my current 36gb raptor as the OS drive
Anyone know any places I can get better prices ? :P
-D
When is this PC happening? Windows 7's ETA is towards the end of the year...
MSY is good for prices... when they actually have what you want in stock!
ETA is end of year but RC1 comes out in a week or so and has a 12 month lifespan
PC is gonna happen in 4-6 weeks, hoping the prices come down a tad...
-D
Are you going to use RAID 0 for Windows 7?
Eventually. I'll use the one SAS drive to start with and then get the second a few weeks later (theyre a bit pricey)
New pc will be running Raid 0 74 GB Seagate 15k rpm's and a single 500 WD Green for non-backed up filestorage
New server will run off a SATA WD Raptor 36gb and then I'll raid 1 the terabyte drives and chuck em in a nice hot swap enclosure (both cases are rack mounted)
RHEL6 hasnt been released yet but I have it on pretty good authority that its only a couple months away. Can use 5.3 till then
-D
-D
Nice :D Those i7 920 CPU's OC pretty hard from what I've seen..... good value
Theyd better be.... theyre the only ones I can afford atm !
The mobo I'm getting is good for a few more generations of the i7 range as well as up to 24 gigs of ram and 3 way SLI, so plenty of room to upgrade later when the prices go down
-D
I can't wait for RC1 to come out.
I am gonna format and redo my Phenom machine and put W7 on 3 x 36Gb 10,000rwm Raptors in Raid 0, with 2 x 1Tb drives inside my LianLi box, and 2 x 1Tb WD Greens in my external e-SATA SuperBox - should do for storage for now - but Adam have just released that on May 17 they are effectively doubling their data allowances - I am currently on 60Gb - will change to 60Gb for use between 8am and midnight, then ANOTHER 60Gb between midnight and 8am. 120Gb of {mostly NewsBin/SABnzbd} data per month - swoit!
Hoping that W7 kicks ass on 3 x 36Gb raptors striped, even on a lowly Quad core Phemon 9500! If only the x86 would see more Ram I would add another 4Gb OCZ, but I can't be arsed getting x64 to work properly, as it is my daily/work machine, and Vista64 was a major headache.
Have also sourced a kick-ass 4850 1Gb card to upgrade my existing 256Mb GDDR3 3850 (which has been awesome to tell the truth).
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
