interesting Matthew that the Q6600 with less speed still beats the newer CPU with more speed so one might guess its all the cache the Q6600 has
yeah i might uninstall FF
I would agree.. the old AMD budget cpus were full fledged rigs just minus cache and limited them severely. I spose yours being quad core and mine being dual your advantage in the memory stakes is cache.
BTW I just ran 3dmark06 with it at 4ghz as on the previous everest stats and improved the score to 16423 not a bad jump for no money.
nice what gfx is that with
Thats with an ATI 4870 512.. almost bought a 4870 x2 on sunday to add to it but really need to buy those coil packs lol.. stag come first... sometimes.
That 4ghz is on air cooling too... mind you it only just squeezes into the case height wise
Edited by Stagstock
ah nice i just booted back into win7 and FF works :D
running @ 3.4ghz benched 3d mark 06 and score another 2k on previous score, took a few goes to get it to book properly had to lower the FSB each time
>>14278 ORB<<
super Pi not that much different @ 15.332 Checksum: 01D34DA9
will edit with CSS frames
CSS saw a healthy jump in FPS from
Pass 2 251.98 - fps_max 400
Pass 3 256.88 - fps_max 600
Pass 4 244.08 - firefox open in the back ground
TOO
Pass 1 276.68 - fps_max 700
Pass 2 277.29 - fps_max 700
What's your GPU clock & memory clock cos the score looks higher than norm for stock HD4870 512Mb (ie. 750Mhz/900Mhz)
Nice job...now run Linpack to see how stable it is :(
I might get back to O/C since winter is arriving...in summer I managed the E8400 (E0) @ 4.46ghz (496x9) with 1.49vcore aircooled, any higher it would crash if I tried starting up in standby mode. Also, main restriction is the mobo as it struggles to handle FSB higher than 525-530 so theoretically ~4.8Ghz (530x9) would be it's limit.
The beauty of the dual cores :) 525-530 is f**kin' decent, what motherboard?
My Q6600 hits FSB wall at around 460-470FSB even when I drop the multiplier to 7 :D I think the sweet spot for the Q6600's is multiplier at 8 and use the CPU Strap to raise the memory bus.
Yeah the Wolfdale processor are great that way. mobo is a Gigabyte EP45 DS3R, performs almost on par with the EP45-extreme and only lacks the bigger NB and SB heatsinks.
Can't believe even after 2+yrs when it comes to o/c and performance the Q6600 is still prob one of the best bang for your $$.
Those P45 boards were great value. So long as you keep air flowing over those heatsinks you shouldn't have a problem..... I hope Gigabyte did a better job of mounting those heatsinks than ASUS did on mine!!!
One day I'll pull my NB/SB heatsinks and reseat them, probably my only gripe with my Maximus Formula SE board I must admit.
Speaking of Q6600s
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=270385607480
And while I am shamelessly plugging my Habibay auctions, anyone want a nice PCI-e 7600GT?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=270385625022
I will have a PCI-e Asus EAH3850 256Mb DDR3 Video card $120 for sale shortly too if anyone has an eoi.
I will also shortly have a 320Gb WD SATA HDD $40, 400Gb WD SATA HDD $50 and a 500Gb WD SATA HDD $60 for sale soon if anyone wants some storage.
what you mean when i comes out tomorrow Helso already has it
i too had one of the early versions of the RC, got it on april 2.
there is a newer publicly available RC out now on the m$oft website
whats that FF add-on that saves all ur other add-ons to a remote server?
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
