My work laptop (this one I'm on now) randomally without warning does weird shit where the screen goes either black or pink and I lose whatever I might have been working on. Have to force off and reboot and then it works again.
help desk just had my reseat the RAM. still no worky. see what they come up with next.
SO, i connected a secondary screen and ran Primary Hard Disk Self Test, results are "#2 - 07 Fail". HP tells me i need to purchase a new hard drive. I dont see how that affects my display tho?
Can you access anything on the drive, I'm assuming you can because you ran the disk test? With the second screen plugged in can you access Windows or is it not booting from the drive at all?
If so I'd get any or all data off of it while you still can.
Ok so i managed to ferry files from my laptop to work pc via USB. Looking at HDD's, Western Digital 2.5" 250G, $88 from MSY. is this what i need?
yeah but make sure you get the right one (IDE or SATA)
If you're going for a new HDD, get one with high rpm (7200 minimum) you'll notice a huge performance gain on the 5200 rpm drives. Get a Solid state drive if you can afford it. They have the best performance but they are rather expensive unfortunately...
-D
EDIT - I still cant fathom why a hard drive fault would cause your screen to stop working... I smell shenanigans
Edited by Dohmar
RE: your Edit: thats what i was thinking, i asked this from HP help, and they said the OS might control the video... pretty open ended answer. My comp still seems to work fine, maybe ill run Preimary Disk check again to double check.
thats bullshit
the BIOS controls the video until the operating systems driver overrides it. call them up again, cut sick and demand that you speak to someone who isnt incompetent
-D
i got this email back from them:
Hello Damien,
Thank you for contacting HP e-Solutions.
This e-mail is with reference to Service Incident id: 1953674 for Compaq Presario C554TU Notebook PC.
I understand that the display is very dim, but there is display on an external monitor. Also, the hard drive failed the test from BIOS with completion code 7.
The notebook needs to be repaired to resolve the issue. Our records show that the warranty of the notebook expired on 26 Apr 2008 and hence the service is chargeable.
Please provide the following details to setup a service event:.................
So i said:
Hello,
So all I need is a replacement Hard Disk Drive? Or is the screen a different issue?
Reply:
The issue with the dim display can be resolved only by replacing the display panel as there is display in external monitor, but very dim display on the notebook.
Please e-mail us the above requested information. We will be glad to further assist you.
Regards,
Vijayasarathy
Technical Support Engineer-HP e-Solutions
    • bump. Anyone had this done? either 49 or 50mm? Been pondering what to do while mines in storage. Been thinking of DBW but if I do that, then might as well do this too. Want to retain 6 throttles. I have a fully build head(CNC, OS valves, 286/278 cams, etc etc still running squish), and a Greddy old school intake with port matching. Head bench flowed 300cfm. Wondering whether bigger throttles will give me any gains. Makes 563kw.
    • If anyone has any suggestions for a 300-350mm long (or thereabouts) muffler that is 3inch in and out I'm listening
    • It's the same with many brands that find their way into promotion via Youtube channel sponsorships. Those stainless guys, e-mail cut shippit, various other service and product companies.... they try to make it so that the only name that comes to mind when you think of doing those things is them, and then you just go get their stuff because your favourite channels are using it, so it must be good AND good value. Notwithstanding that the YT'ers don't pay anything for it. But a lot of people are not that sophisticated.
    • Yeh vibrant looks a bit overpriced, but thats the US market in general, they pay $50k for a gtst...
    • It's surprising you say this because talking to someone who headed Toyota's CARB certification efforts and was now working for Mercedes doing similar things he said he never had a case where he found that it was necessary to reduce ignition timing for that reason. Knock limits yes, but never because of in-cylinder emissions profile. I'm guessing between EGR and the number of TWCs modern cars stack in series it's not really a problem. I really doubt the NEO is that big a difference. You get what, EV6 injectors, coil on plug, a cold start valve that works off coolant temp instead of basically fixed time constant valve, and... I really can't think of anything else. Not like Toyota where they shipped first gen GDI in the 2JZ-FSE.  Something I didn't realize is that Japan didn't revise their emissions standards for light duty passenger cars between 1978 and 2000. I'm guessing there's a bit of phase-in, but that explains why 2002 killed a bunch of JDM sports cars off all at once. FD3S, A80, S15, Z32, R34, Z15A GTO all died off for that reason. And explains how all these cars got away with no EGR or much of anything other than a TWC and charcoal canister for the longest time.
