i just paid $145 for Win 7 home premium OEM so had to buy 1 piece of hardware too so i got a 808gb hd for 71$
hah awesome. msy? i love windows 7. so smooth. so glossy. australian are so rucky to have magnificent outback.
-D
nah Ben, not in a position, nor necessary to upgrade the E yet.
How did you get away with buying one piece of hardware to get Win7 oem Steve? Last time I bought an oem from MSY I had to buy a CPU AND a mobo AND a hard drive :happy:
i was just handed a legit cd and key (64bit) about 2 months ago and gave it a try and havent thought about going back to xp or vista... so it must be good.
btw i havent posted in a year i was expecting "WHERE THE F&^* HAVE U BEEN".
Edited by Pauly33GTS-t
-D
Checked out the other theme packs they've hidden away? The Canadian wallpapers have some great views.
C:\Windows\Globalization\MCT. iirc
Where do you buy oem software from Steve?
You could get it from me...only when i am at the Noarlunga Store though...I cant get away with as much down at Marion :) . But if you want we could meet up on my day off and go into the Noarlunga Store...if they have stock.
^^ i have a friend at the modbury store and she does the same but price is still IT gay
and Hyperomgnet OUCH
Hypernet price >> WD8088AADS 808.8GB 7200rpm 32MB Cache $129
i paid $79 from eastern states even msy has them for $73
not sure if there price list is current but adelaide retailers seem to wack on a fair bit for getting parts shipped from the eastern states
i actually PM'd Andrew where i got it from
Hi Pauly :)
I've missed our little online fights.
yeah i stopped shopping there a while ago but $159 for home premium isnt too bad since there's no hardware catch!!
  • 4 weeks later...
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 馃ぃ馃憤   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 馃槂
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
