for those of us with rFactor inspect-a-gadget has a dedicated server running all the time to which i has admin :D
download the GTR and the touring car ledgons mods with bathurst and its updates and we can go racing
IP:
>>Touring Car Legends<<
i think Bathurst only needs to be 1.1
>>Bathurst<<
GTR 1.1 mod
>>GTR 1.1<<
you will need to sign up @ rfactorcentral but if you do have rfactor you will go through heaps of downloads as there is heaps of good stuff there :)
for those of us with rFactor inspect-a-gadget has a dedicated server running all the time to which i has admin :banana:
IP:
>>Bathurst<<
GTR 1.1 mod
>>GTR 1.1<<
you will need to sign up @ rfactorcentral but if you do have rfactor you will go through heaps of downloads as there is heaps of good stuff there :bunny:
Just be careful you don't double book the server Steve! JFF use the server too so I should give them a plug and get you guys to check out their site too, they're a great bunch of guys who race regularly and would appreciate new guys to race with...
Check here first before you host a game to see if there is a race or practise scheduled, or join up and race with the guys, they're on most nights racing...
http://jff-racing.my-goo.com/
any time they're not using the server, you're welcome to load up the skyline mod or whatever and any track you like and have a blast!
have fun!
Gadget
with the Nismo 34r mod (the best one to use) I have laid down a 2:08.151 at bathurst.
a 2:07 definitely possible as I'm still tweaking suspension settings and have only done 10 laps in the car so far.
Tips...
1, soften suspension
2, change gear ratios till you can get 308KMh down conrod with rear wing on 2 and front splitter on 2
3, MUST increase brake ducts to as big as you can. Brake fade is a MAJOR problem with brake temps over 1100degrees!!! brake at the kink in the end of conrod, and pump the brakes, brake earlier here, because by the final turn, the brakes don't get enough time to cool and you can end up in the fence with no brakes!
4, use torque split of 35 front 65 rear. or 30/70
5, increase tyre pressures and play with camber settings till you have even tyre temps across the tyres. cold in the middle, add pressure and vice versa.
6, slow in, fast out
7, drive smooth, smooth is fast, don't try to drift, it will, but don't try!
8, raise rev limit to 9000RPM
hope that helps, and gives you something to aim for!
Gadget
Edited by inspect-a-gadget
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
