Hey guys, just wondering if anyone can tell me what's a semi-decent free AV and firewall combo these days? Going on my old laptop with XP Pro...
Microsoft Security Essentials FTW. Works well, updates automatically and uses almost no resources at all.
http://www.microsoft.com/Security_Essentials/
anyone got GTA 4 Steam Files???
cbf downloading 15gb haha
I dont have it on Steam, but if you know someone that has the PC version you can install it off of their Disc, and copy the install folder into you steam/steamapps/common folder (while steam is closed). Open Steam once copy has finished, and you may have to download 500mb, and your done...i just did that with Burnout Paradise Ultimate Box and it worked fine.
Hard to believe that is true isn't it...but it is according to this
It really is a neat program, I've been using it for months now and I've never had a problem with it, and it's always detected all kinds of malware I may have accidentally downloaded. Perfornace-wise, it's so good, it even works great on my parents' 8 year old Windows XP computer!
im silly enough to try it :woot: been running my win7 with nothing since i installed it :D
does it stop virus's too or just malware upon initial installing it looks like its defenders replacement
would be good if it could do the job with one single program and no 10%+ cpu use like norton shite
let us know what u think. currently have avast on here which is ok
-D
Viruses and spy/malware. Make sure you get the right version, 64 or 32 bit.
-D
Norton Antivirus CE is where it's at, low resource use
probably means its just not doing its job
ive never seen a norton AV product that i've liked, theyve all been pretty hefty on the cpu usage, or poorly designed with viruses that takes advantages over norton induced backdoors, or it corrupts itself and the tcp/ip stack requiring a reinstall...
only reason people use that shit is cause its pre-loaded and theyre generally too lazy to upgrade to something decent ;| and because its pre-loaded with security flaws, its a prime target for enterprising hackers
norton ghost, disc doctor, windoctor and speedisk are good norton products, its just a shame they cant make a decent AV
-D
-D
and you call yourself an IT expert :/
back in the day Norton used to be the best but then he later sold it to symantec and it turned to a process hog that really in todays language is a virus itself once you install it you cant uninstall with without a special uninstall tool
It does happen to be my day job Steve. Unlike a lot of so called 'experts' I have the qualifications and 15 years professional experience to back it up.
Back in the day... We're talking 20 years here, back we we used to run command line AV scanners and TSRs upon a DOS boot. Peter Norton hasnt been involved for the last 2 decades, so I stand by my statement that they (Symantec and ergo Norton) cannot make a decent AV.
-D
-D
Or maybe it means it's actually good, just cos it isn't a resource hog doesn't mean it's not good; it just means its optimised and coded properly. A corporate environment requires it to be fast and bloat free or else it wouldn't be used. Hows about you try it before you knock it? It's not your average Joe antivirus that Dell or HP preload on their turd PC's and give to consumers
My clients have used it before and its been an utter POS - like steve said, there are times when norton becomes a virus itself, with backdoors and buffer exploits that get taken advantage of by those who write malware. Conversely, just because its not a resource hog, doesnt mean that it actually has a thorough scanning engine - McAfee used to have that problem on their consumer level software up until 3-4 years ago, however now McAfee and Trend Micro (as well as CA -Etrust which ironically is also owned by Symantec) are currently the major corporate AV's in use, generally because people do not trust Norton branded AV's based upon their shoddy consumer level software.
I will however point out that my criticism for norton is solely based around their consumer rather than corporate software, however actually having seen the corporate edition I can't actually say that I'd trust it further than I could throw the box it comes in.
-D
you used the term Never meaning period i was just clarifying that in its heyday norton was the best
considering hardware doubles every year and software is superseeded every 2-3, I hardly think quoting something from 2 decades ago is very relevant ;P Thats like saying dos 6.2 is a totally awesome operating system ;P
-D
-D
Ok
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
