Hey guys, Ive got a really weird problem. I have just changed ISP's and my email doesnt work anymore.... Not 1 setting on the PC was changed (because I use ethernet), and the email I use is Hotmail with Windows Live Mail as the program... WTF?!?
Might be coincidence you say? The bigpond email wont work on my laptop either, which is connected by wi-fi using Windows Mail.
Kinda baffled here :(
1. What Firmware is it running? Should be printed on the top...pray to god it isnt the faulty batch of SD15 drives - they shouldnt have been released in Australia anyway, but grey importers, etc bring them in.
2. Have you tried a different SATA cable and SATA port?
3. Have you tried resetting the BIOS.
4. +1 Does the drive spin up at all, or make any weird noises?
Nothing too much you can really do with hard drives. Sometimes you can change the controller card, but you need one from a working exact same model and firmware drive, even then it isn't guaranteed to work. You can try a data retrieval place, if the data means that much too you, but be prepared to pay ~$1000 or more - They take the drive apart in a special chamber, take the spindle out, and place it into a spindle reader.
He cant get into Windows as the 1tb drive is his C: Drive - The drive Windows is on, and the Bios doesn't see it.
1. Firmware = SN04
2. Yep, and other drives work off of the same cable and port.
3. Nope, but the issue is that sometimes the PC will hang during the POST, and the BIOS always fails to recognise 2 of the other drives when this drive is plugged in = not good and also strange.
4. The drive does spin up, and with no weird noises, so that's something.
I'm fairly sure if I had access to another drive with the same f/w rev (or maybe even different f/w) the board could be swapped and the drive would work.
thats in a coffee time patch ;)
heh nice. they should also put in an 'infidelity timer' so if u take too long playing with the whores, elin nordegren pops up with a golf club and its your job to evade her, make your way to the black SUV and drive out of the gated community to south central LA, where another whore is waiting...
too bad tiger didnt take notice of the timer
-D
Woot.
Uranus is back and waiting for me to fill it again. :D:blink:
Now if only Saturn would work again...
***Probably only Dohmar will know what I'm referring to***
It means that daves favourite hoe is back in adelaide
but he laments the loss of another good (retired) hoe..
nah thats not right... >:)
-D
going to do a grandparent thing here..
"I remember back in the day that this thread was only a few pages long"
i was talking about getting a new pc..
I FINALLY DID YAY :(
hehe grats i know what thats like
took me 12 months ;P
-D
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
