lol sorry man this i really dissagree P4 3.4 2mb cache is no way near on par with 3200+ try a 3700+
P4 will do encoding and office stuff better 3700+ will do 3dmark and games better
both PC must be running simular hardware like same hdd same amount of ram and most importantly same gfx card
Getting 2 laptops for the old cronies at work.
they have just started using pc's, lol
which one would be your choice on a 2k budget, each? Ive recommended Asus, in particular the F3JP over the V6J but Im not with it in regards to laptops (never used one) and core duo etc.
http://www.asuslaptop.com.au/asus-notebook-special-deals.php
or
http://www.eyo.com.au/prod_P-V6J-P_proddes...1181806S1G.html
sweet :)
Apparently the 4600+ dual core is equivalent to 2 x 3800+ single cores, so even while not utilising the extra grunt available from the second core, it should be 20% faster.
Really the only time I need more power than I have now is when I'm encoding video, and doing things while playing a game at the same time - this is why I chose the dual core 4600+ over the FX-55 single core I could have purchased for a similar price.
Just a cpu upgrade - already running 2048Mb ram.
Final specs will be:
AMD A64 X2 4600+ (S939)
ASUS A8N-E MOBO
2048Mb RAM (4x512 DDR400)
XFX 7900GT (PCI-E)
800Gb storage (160+320 internal, 320 external in MediaGate)
Viewsonic VX2025WM
Hopefully the only thing I'll have to change in the next 18 months is to add some more storage as it begins to fill up.
I've just gone halves in a webserver that we're building for co-located hosting... check it out :P 8x3ghz and about 16gb of memory.
Processor #1 Vendor: GenuineIntel
Processor #1 Name: Intel庐 Xeon CPU
3.00GHz
Processor #1 speed: 2993.411 MHz
Processor #1 cache size: 2048 KB
Processor #2 Vendor: GenuineIntel
Processor #2 Name: Intel庐 Xeon CPU 3.00GHz
Processor #2 speed: 2993.411 MHz
Processor #2 cache size: 2048 KB
Processor #3 Vendor: GenuineIntel
Processor #3 Name: Intel庐 Xeon CPU 3.00GHz
Processor #3 speed: 2993.411 MHz
Processor #3 cache size: 2048 KB
Processor #4 Vendor: GenuineIntel
Processor #4 Name: Intel庐 Xeon CPU
3.00GHz
Processor #4 speed: 2993.411 MHz
Processor #4 cache size: 2048 KB
Processor #5 Vendor: GenuineIntel
Processor #5 Name: Intel庐 Xeon CPU 3.00GHz
Processor #5 speed: 2993.411 MHz
Processor #5 cache size: 2048 KB
Processor #6 Vendor: GenuineIntel
Processor #6 Name: Intel庐 Xeon CPU 3.00GHz
Processor #6 speed: 2993.411 MHz
Processor #6 cache size: 2048 KB
Processor #7 Vendor: GenuineIntel
Processor #7 Name: Intel庐 Xeon CPU
3.00GHz
Processor #7 speed: 2993.411 MHz
Processor #7 cache size: 2048 KB
Processor #8 Vendor: GenuineIntel
Processor #8 Name: Intel庐 Xeon CPU 3.00GHz
Processor #8 speed: 2993.411 MHz
Processor #8 cache size: 2048 KB
If you're after quality website hosting contact me! :D
Asus more reliable than Toshiba? Care to elaborate on that comment?
I know nothing about laptops. Nothing. Do Toshiba make their own components?
I simply figure seeing that Asus manufacture top motherboards and videocards (that cant be argued) then a laptop from Asus should be good quality.
Budget was originally $1500. Then one of the bosses suggested he wanted core duo (let me point out that the 2 bosses have never used a computer in their life until the past couple of months), so I upped the budget to 2grand to accomodate this. My suggestion was sata HD, 1gig ram, min 1.6ghz, etc, and I havent seen a new Toshiba with those specs for under 2k.
Cheers anyways, but Ive decided to get them the Asus F3JP, something that will last these 2 minimal users a good 5yrs or so. All they will be doing is word/exel & emails for work, rarely ;) , and internet browsing & maybe using the laptop with a tv tuner down the track.
Are Assus considered to be un-reliable ? :)
meh, Im not concerned either way, 18more hours until my surgery, is the biggest worry on my mind.
Brendan
Toshiba do tend to be a tad more expensive than some but they really are top quality laptops.
Asus should be ok, its not like its an Acer. :S
Its just that Toshiba are well known as a reliable business laptop.
Toshiba make their own chassis's just like Asus do. There was a time when Asus made chassis, then sent them to local retailers to assemble. I had built quite a number of Asus laptops, and found them better than your run of the mill non-branded chassis, but the top shelf stuff has always been IBM/Toshiba who do all their building in-house.
It's only recently that prices of IBM (Lenova) and Toshiba laptops have come down. Up until this year, sub-1000 dollar Toshiba laptops were unheard of.
I'd go for Toshiba personally, but i'm not a huge fan of their design. Recently i've been purchasing Dell laptops for our workplace, who has slowly migrated from Toshiba laptops. I've had no problems with Dell so far, and their top end lightweight gear is actually pretty bloody awesome, so much so i'm considering buying one for myself.
All the best with that mate.
Cheers Howie.
lol, I expect to be using my PC a fair bit over the next 4 weeks during recovery; go BF2.
might try overclocking the unit (p4 3.4, gigabyte mobo, 2gig ram, 7800gtx, raid 400mb sata HD, 9 fans) to 4000, havent gone past 3700 (8%) as yet but its been real stable and heat hasnt been a real issue
ASUS A8N-E MOBO
XFX 7900GT (PCI-E)
Viewsonic VX2025WM
lol at 800gb. :(
I run a 120gb thats happily 60% full. 8gb worth of family pics, almost 2gb of car related pics, a few bits of software and a couple of games (BF2)
I throw everything off to DVD and store it away, have a nice little program I slapped together to help me trace down what I need at a later date. Tends to be a bit of a habit I have now after loosing a few WD drives one after another (3-9months between failures) a few years back. This was back before the JB drives.
What ISP are you with?
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
