  Nightcrawler said:
we are both with Node, on ADSL 1.5Mb .... unfortunately we both live in Northgate, so our phone lines are on a RIM, hence we can't get ADSL2 or + ;):);) ;)
Well that just plain sucks..
  chops said:
Internode here.
1500/256 40Gb/month.
I DO need to do some cleaning out of things.
hehe yer that or nodes premium usenet pron service. :(
  Tangles said:
Cheers Howie.
lol, I expect to be using my PC a fair bit over the next 4 weeks during recovery; go BF2.
might try overclocking the unit (p4 3.4, gigabyte mobo, 2gig ram, 7800gtx, raid 400mb sata HD, 9 fans) to 4000, havent gone past 3700 (8%) as yet but its been real stable and heat hasnt been a real issue
:P
get a nice fan and u will easily see 4ghz stable
Nice Fan
I went for a Thermaltake Blue Orb 2 (about the same price) and it is quite unbelievable - it is absolutely silent, is on automatic speed (ie. the hotter the CPU gets the faster it will spin to try to cool it down), and the hightest speed I have seen it go is 1,200rpm (still silent) and the hottest I have seen the CPU is 45 degrees when hammering it. Currently it is 23 degrees ambient, 39 degrees CPU at 830rpm .... quite unbelievable for a dual core X2 4200 @ 2400Mhz (4600+ speed).
Lik-Sang were an import export company of videogames. And in the past year or two sony have been sueing them and they have finially had enough and probably can't afford to keep fighting these battles.
Go to www.lik-sang.com if you want some info.
In other news i got to play the Nintendo Wii tonight and it is so damn good it's unbelievable. It's so fun using the remote and the online functions are awesom and well thought out.
Everyone should be pre ordering one.
December 7 $399 and you get wii sports. Which has 5 sports games in it.
So good.
P.S buy my R34 so i can get a V35.
I saw the black V35 coupe that Synergy brought in for their compliance (that I posted some photos of a while back) driving on North east Rd the other day .... unfortunately it was going to other way so I only got a quick flash of it. *drool*
If I had known how soon V35 compliance was to be available when I bought the R34 last July, I would now have a V35 in my driveway instead of the 34 .... but I had committed to buy the R34 when I found out :) .... bloody fantastic cars (if not very lacking in power) - even Jeff from C-Red owns 2 of them and absolutely raves about them!
I couldn't work out why I couldn't beat Steve's score - all I could get is 35.5 seconds - but then it occurred to me that SuperPi only uses 1 of my 2 cpus (dual core you see) :P
A more appropriate Pi test is the multiple core version here: http://www.hwbot.org/download/multipi-0.2.zip
I got 1 min 23 sec @ 2.75Ghz - that is the highest I have overclocked it to so far .... I will get it to 3Ghz when I have some more time to play with it! (For some strange reason the multiple core beta starts time at 30 minutes rather than zero - but I assure you it is not true! lol).
Everyone post up their scores to compare!
to get super pi mod to utilize dual core u need to run 2 instances of it from to different named directories, then u can task manage the ifinity of CPU's to each program executable
i also dont understand the program u used i ran it any way
Running Stock
Running 4ghz
Super Pi 2 instances Stock
Super Pi 2 instances 4ghz
Steve I am pretty sure the program I gave the link to calculates Pi to 4M places, and utilises both cores to do it. When I calculate SuperPi to 4M it takes 2:42 with one of my cores, and that program takes 1:17 (now I have upped my clock to 2.925Ghz *and it is still stable* - that is equal to an as yet unreleased X2 5800+ :rolleyes: )
oooh yeah I just benchmarked my CPU in Everest Ultimate Edition "CPU Queen" and topped the list - eat my dust overclocked Intel Core 2 Extreme 6800 @ 2.933Mhz - my beastie at 2390.5Mhz kicks your butt :P
And for those that play CS:S go do the stress test .... I got 146fps with my XFX7600GT @ 1,280 x 768 4xAA :rolleyes:
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
