WOW msy is getting fancy they have changed there website so you can actually make an account and put stock in a cart no delivery as yet but you choose pickup and i guess select the store you want to pick up from
Its handy to see if they actually have what you want in stock, rather than trying to ring them and have no one answer :rolleyes:
Turned on my desktop for the first time in ages the other day to install NFS, and to my surprise the gtx260 I bought over a year and a half a go can still put out 1920x1080 with everything set to high and a decent frame rate..
Does anyone happen to have a 20-24 pin PC power supply adapter laying around I can buy? I want to fit an older (but awesome) 20 pin Thermaltake PSU into a PC I am making the lad for Xmas, but newer motherboards are of course 24 pin.
What I am looking for is like this : http://cgi.ebay.com....=item2eaf34d7b0
I have ordered a couple off Ebay, but assume they won't get here by Xmas, so if no-one has one locally I will have to go buy a cheap PSU for the PC, which would suck. Anyone got a converter laying about?
I don't know for certain about the latest boards, but the earlier ones (first year or so when 24 pin was used) could run off a normal 20 pin ATX.
Failing that, I bought 2 430w thermal take psus from MSY a year a go for about 40 bucks each, one's been runing a c2d + 6 hdd's fine ever since, and the other is still powering a 2x100wrms car amp.
ordered a few goodies today :)
Fractal Design Define R3 Titanium case
AMD Phenom II X6 1100T Black Edition CPU
Sapphire Radeon HD6950 2GB Graphics card
Gigabyte GA-870A-UD3 Rev2 MoBo
CoolerMaster GX 750W PSU
oh jealous much :D
Great case Carl.
I've got one also.......................very well insulated for sound but it's pretty heavy unfortunately
I have no idea how you guys justify spending that much money on an upgrade to your PC when in a year it is worth nothing. I have built a PC that won't quite look as good, and will only be 90% as fast, but cost a quarter of the bits you are getting Carl.
all the bits i have ordered are actually quite middle of the road apart from the vid card. also by going back to AMD i am saving a good $500 that would have gone towards paying for the word intel.
the fact of the matter is, if im not spending unnecessary money on my car, its going on the PC.... neither are an investment by any stretch of the imagination lol
About $1k
quite decent
I spent around $2k last year on memory (12gb), psu (850w), vidcard (r4890), cpu (i7 920), mobo (p6t deluxe v2) and 2x 1tb hdd's... then another $1.5k this year on ssd (50gb revodrive), case (coolermaster storm sniper black), bluray burner (LG), tape backup unit (Quantumn DLT-V4), keyboard (G19) and another 2tb hdd (WD Green)...
last pc worked for a good 5 years, I'm hoping the current platform I have will last that long (it should provided I upgrade the videocard and cpu when the cpu socket gets to its EOL)
-D
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
