R factor is free to Down LOad you have to pay for it when you register, I have broad band but my Ozemail account its really slow 3kb's and i only have a 300mb DL limit:(
i'm just after the setup and installation files
M8 you didn't have to DL it i was after someone that already had it
Edited by Whiplash
well as i said the download is 688mb i have it now but dont u live down south
**EDIT**
ive used 58% of my monthly quota and im not about to use 4gb in 4 days since it a legitamate download i got no problem helping cept for the fact i dont have anything but DVD's to burn it on where about you work and maybee we can arrange sumthing
Edited by Madaz
Guys im noticings you are all pretty cluey i need some tech support i recently had this cpu in my MSI K8T Neo-FSR Motherboard ----- Athlon 64 3000+ 2000 MHz 512 KiB 800 MHz 10x 1.50 V 89 W Socket 754 ADA3000AEP4AX until i broke of one of the pins on a fan clean (bad story).
I got another cpu which i thought was just a desktop one but after changing power supplies and ram i noticed it was a Mobile one. Is this CPU my Problem??????? ------ Mobile Athlon 64 2800+ 1800 MHz 512 KB 800 MHz 9x 1.35 V Socket 754 AMD2800BKX4LB
DRIVING ME CRAZY
ps ( my comp problems were automatic reboot, memory dump, irq issues, stalling in bios setup)
Hope someone can help
Erin
what type of ram are you running it may even be driver issues
sum AMD chips require extra drivers
AMD Athlon™ 64/FX Processor Driver for Windows XP
if thast isnt needed im sure someone will say
More stuff to monitor your chip here the last few look ok like AMD Athlon™ 64 Processor Cool'n'Quiet Software
http://www.amd.com/us-en/Processors/Techni...71_9706,00.html
maybee your PSU is fluctuating in its volts and when it does your cou reboots
Edited by Madaz
I doubt the Mobile chip will be the cause unless its faulty.
I'm not sure how it is with the A64 Mobile chips but previously mobile chips are nothing more than a high grade desktop chip that is able to run high frequency's at low volts. So the item of choice for overclockers.
Have you tried the usual bios update, rip one stick of ram out, memtest etc?
lowered my 7950GX2 price to 650 dollars now. its brand new. thats a 110 dollar drop. details found in the For Sale section in the forums. RRP still around 1000 dollars and this ones new (4 weeks now) and never been OCd.
http://www.skylinesaustralia.com/forums/in...howtopic=143697
In regards to your problem. Can you state here what:
Motherboard
RAM
CPU
PSU
3d CARD
Hard drve
And then we will be able to have a slight clue as to what may be happening.
Edited by SAZilla
Skippy, I have a XP 3200+ you can have for $50 if it will get you out of a spot. Obviously no charge if it doesn't fix your issues - yes try before you buy. Comes with stock heatsink and fan, but will need new thermal paste. Let me know.
try doing this, if you have dual channel set up, take out a stick of ram, then if u installed the CPU yourself, make sure the fan is on correctly, might even be a heat issue for all we know. how many PCI cards, cd roms, hdds and what graphics card do you have. you problem could be a power/heat issue. causes alot of lockups.
do a bios clear by shorting a few designated pins on the motherboard with a jumper and then see if that helped. Look in your manual for the motherboard on how to clear the bios using the jumpers on ur board.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
