lol. check page 1 post 1 :(
i dont make things tidy, i just want power.
I'm more pro evo geek than a computer geek, give me a ps2 and a game of pro evo 6 anytime ill whip ur ass.
Edited by SAZilla
Just a question, hopefully its welcome..... But has anyone had any problems with Windows Live Messenger?
For the past few months i have been having problems and its driving me insane! First i thought it was Spyware - No, Virus - No so what else could it be?
Problem is all of a sudden my CPU monitor shows its using 100 CPU on WLM, so i end task it and it drops back to normal 3-4% then like 20secs later WMP will topple and start using 100% CPU, its like a domino effect and i have never been able to end task them both.
It frezes up that much that i just have to push the reset button which i hate doing!
Anyone had any problems like this?
Any help or direction would be appreciated!
PS surprisingly i havn't found anything on the net about this problem :wave:
it is a known issue. I would try searching the net more for "MSN crashes computer" or "Live messenger crashes computer" you might find results.
if that dont work, update your windows box with all the patches, if that doesnt resolve, delete live off ur computer then use CCLEANER to clean up your registry files (can be found on www.tweaksrus.com), then reinstall msn live. i cant believe im doing my day job, within my day job, at work, on a SAU forum lmao. :wave:
One of my mates is worse, he is in a number 1 clan for Enemy Territory and he has his 'pro gamer' room. The thing is he doesn't look like your typical geek, he has his room with a mini bar, massive tv, all your cool stuff then he just closes the door to the other room if any girls come over. Massive neon case, random monitors and computer shit every where, its hilarious.
lmao, my pad is cool, ferrari flags on the walls, micheal shumacher pictures all over the place and ac milan banners and a few girls, and then in the study it looks like a freakin computer tech area workshop. its my job if any1 asks lol. i just happen to muck around with technology at home wihtout caring for it very much. my cars coming in soon so im probbaly get pretty bored with computers for a while.
ok here is picture of hub havnt had a look online for it yet
also i need a program preferable open source that will recover files from a format
EDIT
im trying GetBackData at the moment
Edited by Madaz
ive asked 2 questions i think SAZilla was talkin about the data recovery of the hdd
a program called 'Get Back Data' works but its 79 bux US
my mate doesnt want to pay that much to recover some photos
we had to format his PC becuase it wasnt loading and wasnt going into safe mode
its only low level format just need a cheap good program to recover formatted data (i dont pirate either)
1) where do i buy it (see previous post)
2) does it show you every file that was on the drive before formate and let you choose which ones to recover
im seriously thinking of just shelling out the beans for the program my self and then charge my mate a service fee for recovering his data :)
Madaz,
So its only been formatted? Nothings been installed?
I use this little utility on my usb drive.
http://www.snapfiles.com/get/restoration.html
Its not the best but its lightweight and does the job well providing you don't overwrite data. Most likely it won't work if the volume has been formatted.
I haven't really looked hard but there appears to be a few utilities that are free ware and work with formatted drives.
http://www.snapfiles.com/Freeware/system/fwdatarecovery.html
cheers yes formated reinstalled OS and 11gb of stuff back on a 120gb hdd
my mate seems to think it writes to totaly blank sectors first
the hdd was never full either only about 11gb before total crash
When you format a hard drive it does not completely wipe the disk by writing Zeroes to the HDD. That is the difference between a quick format and a normal one. If the disk had been quick formatted and only 1 large lartition setup on the new disk then your chances for recovery are pretty good, but if the data was written in the first sectors of the HDD like your windows installation and you never defraged then your chances are pretty slim. From what I understand anyway.
thats partly correct SAZilla
as my mate explains it better he claims a government format is where data 0 and 1 is written on the disk 7 times would take all night to format your disc this way
both ways to windows format quick and full are only low level format meaning data is recoverable
i did say 1 program can recover it but it cost 79us i ran the program and have seen all the data is there that i need just need to pay for it now
any ways im trying 1 from the site that cubes posted sumtimes it takes a fresh set of eyes searching for a program that i missed
    • I should try the experiment you're talking about, the throttle switch is still there carried over from the R32 and it's still all wired up but after I did the whole intake manifold refurb and had to recalibrate the TPS I managed to somehow get the idle switch reporting activation at 0.22V, then when I adjusted it to 0.45V for idle it decided the engine was permanently no longer idling which caused some very weird behavior, closed loop idle was disabled so it would basically be at the whims of the cold start valve and whatever the base timing table was at. Then just unplugging/replugging the TPS with the ECU live caused it to relearn the idle TPS position and decide 0.45V was idle. Presumably there's nothing in the TPS that allows for the throttle switch to "recalibrate" like that, not easily at least.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
