That's an offensive cost to the environment. Future archaeologists will be able to identify a "Vista Upgrade Layer" when they go through our landfill sites.'"
The sad part is thats probably true. However a lot of people do recycle machines, theres a company in the hills that takes old pcs (pentium 3s etc) fixes them up so they can get on the internet and do word processing and sells them for next to nothing. A P3 is really all you need to do 80% of office tasks.
Edited by Rolls
the UK Green Party are a bunch of uneducated freaks .... what DRM has to do with anything whatsoever is beyond me .... and the claim of people dumping old monitors - this has nothing whatsoever to do with Vista lol
hi man,
AVG is good Spybot is good
personally i used Active Virus Sheild from AOL and kapersky
http://www.cpuid.com/cpuz.php that will tell you all sorts of good information about your pc including how many ram slots you have
forget about upgrading your laptop, period. They are notoriously temperamental, and you will require specific model and spec ram chips from the supplier that built the laptop - and these are normally 200% - 300% the price of generic PC ram.
hey guys, how can i find out how many RAM slots i have in my laptop?
also, what do people think of AVG anti virus, Spybot and Sygate firewall????
I used all 3 for ages, and think they are great as they are free to use and catch 99% of stuff.
Currently though ive switched to Bitdefender as i thought avg was letting something through...
Bitdefender was my choice amongst the highest rated ones as it has the option to scan fast like AVG, or do a full or deep scan like Kaspersky, NOD32 etc...
It also has an included firewall, spyware and malware package in the 1 program. Saves me updating the 3 programs u listed, then scanning each.
ATM i cant be farked figuring out why vista wont run on my pc. Memtest has no errors, and nothing is oc'd.
I think it must be the way ive got my hdd and dvds setup...
DVDr is pri ide drive
DVDrom is the Pri. ide secondary
Raptor (boot drive) is in sata2 -port 1
Seagate (storage) is in the sata2 - port 1
I think vista cracks a shit if it aint on an ide slot....need to keep researching....
for now im having fun, as ive got Ubuntu dual booting with XP. Planning on seeing how Beryl goes, and what else i can get going on linux...
I have Vista running an a SATA drive no problems.
I would definitely not run your DVD burner on a primary IDE port - put the Burner as Secondary master, and the DVDROM Secondary slave.
i forgot to mention before Active Virus Sheild is FREE also
http://www.activevirusshield.com/antivirus/freeav/index.adp?
*Powered by Kaspersky Lab, one of the largest anti-virus providers, worldwide.
Edited by Madaz
isnt it better to run each on a separate ide port, not master/slave on the 1 ide slot?
Any difference to read write times when copying / writing from a disc to another?
black32 - I have always run DVD/CDRoms and Burners on the same ide ribbon and don't notice any speed issues - I have always done it this way. The read/write speed of the drives themselves is by far the limiting factor.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
