  Ryanrb25 said:
what does this say in some sort of english guys, is what i have good?
thanks fello freekazoids
go to the SPD tab in CPUz and in there it will show how slot and # however many slots show up when u click it is how many slots you have
but in the screenshot you posted it says DUAL that means your current ram is running in dual channel so theoretically you could run 4gb in the 2 slots that you have asuming theres no more slots
All it means is you r ram is running dual channel ie. your laptop has 2 identical ram chips running in serial or dual channel mode. Chances are your laptop only has 2 ram slots and both are already full.
I don't know where his overclocking comment comes from - your laptop is not being overclocked.
FYI when you overclock a PC you make it faster. So by upping the fsb,the clock speed rises, and your pc goes faster. Like I am running my X2 4200+ system (which clocks at 2.2Ghz) at 3Ghz, which effectively makes my PC a X2 5800+ .... healthy speed increase for no $$$. Downside is the harder you clock a CPU and ram, the hotter they get, and it supposedly shortens their life expectancy. If you want to know more Wikipedia or Google are your friends. You will find literally thousands of articles and websites dedicated to this.
thanks alot, that helped. it says i have 2 slots, with 512mb things in each one. if that makes sene. i know lappies have come along way these days in the way of cooling etc...but is it not a good idea to up my ram to say 2 x 1gb ram sticks...will that cook it? any idea's to help my lappy from not cooking? thanks
upping your amount of memory won't affect your laptop negatively in any way. Since you are not overclocking you don't have to worry about heat etc.
But, you will find the price of 2 x 1Gb ram sticks to suit your laptop brand and model to be OUTRAGEOUSLY expensive!
either its just me or i got heaps of spyware or something but id expect this lappy, 2ghz, 1gb ram 2 x 60gb hard drives to go pretty well....it feels like its lagging behind a bit. just with some things....is it possible to pretty much wipe the hard drive, keeping all my stuff on the hd i dont use and then starting again..to get rid of any spyware etc.... sorry bout all the questions but i use this lappy everyday and its givin me the shites. or is it better to put all my shit onto an external hd and taking it back to where i got it? im just a tight arse lol
  Nightcrawler said:
forget about upgrading your laptop, period. They are notoriously temperamental, and you will require specific model and spec ram chips from the supplier that built the laptop - and these are normally 200% - 300% the price of generic PC ram.
Its not that bad, I sold laptops as my full time job for a year a few years ago and as long as you use the same sticks its fine. Its only older laptops when using new high density 512mb pc133 sticks that they have trouble.
Just get a matched pair and you should have no worries.
Back up your personal shite on CD/DVD/or external HDD, then run the recovery CD the lappie came with. They pretty much run themselves - should format your HDD (all data will be lost if not backed up) and install Windows and all the oem programs.
If you're not comfortable doing it I suggest you take it back to where you bought it, or drop it to me overnight and I will do it for say $50 cash. I am in Northgate - not too far from you I believe.
  Pauly33GTS-t said:
DO NOT overclock a laptop. they have only 1 fan at best and little or NO efficient ventilation. might aswell throw it in the bin, along with 2000 dollars for buying a new one.
At worst they will overheat and become unstable, slightly increased temps barely reduce the lifespan of the chips, its running higher voltages that does. Get a proper temp monitoring program and keep it within 65c on load and you'll be fine. Even if it did kill the chip you wouldn't be up for a whole new laptop.
Edited by Rolls
  Pauly33GTS-t said:
who cares when inexperience can lead to permanent damage. random rebooting even on new installations, undesired effects man... its all a conspiracy.
Geez you could say that about anything, even winding up the boost on your car.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
