Hey Paul,
Whats the jap writing under your avtar in English?
I've thrown it in to babelfish but it comes up with nothing.
My long term goal for my car is for it to be a somewhat Mine's replica.
The Jap writing is "Mine's". :D
yeah I have been playing it on PC for a few months now - have put in over 100 hours! Bloody awesome game, and some of the things that come out of his mouth shock even me :P .... plus I have been beaten up and urinated on on 2 separate occasions lol
yeah Nick it is heaps like GTA .... but has a Scarface slant running right through the game. You definitely will enjoy the game more if you have seen the movie. Still enjoyable even if you haven't though.
cool, may have to look into it when i get some time.
I finally upgraded the pc the other week (wooohoooo) so everything looks awesome. I got a 512mb geforce 7 and atm i run everything on 1280 X 1024 and all textures maxed out.
only problem was stupid me could have sworn i had DDR2 ram and bought a stick of 1gb DDR2 and now it doesn't fit so its sitting on my desk doing sweet fa :P
yeah i was having an incredible "Blonde" day. I could have sworn i already had DDR2 ram in there but naturally i was wrong
when we couldn't get it in i went and got the motherboard book and it had a DDR2 slot after 30mins i realized i had the wrong one......... how embarrassing
so i have to live with 1gb of ram and not 2 :P
I need to remember next time i'm bored not to go and spend money. Lucky i didn't buy a monitor then otherwise i couldn't have afforded to get the car all fixed
not sure off the top of my head which brand, it was on my desk looks like its gone walking.....
hmmm will have to check
hey guys, im fed up....my lappy, everytime i connect to my internet, whether it be at home or on my wireless broadband, any connection infact, as soon as i connect, my computer doesn't wanna do anything. Firefox, MSN, email, windows media player etc , doesn't wanna open up for around 10 minutes. After they open its fine. I can open my computer etc etc. Ive updated and updated my AVG, SPYBOT and have my firewall CONSTANTLY running. What da hell?
avg, spybot shouldnt be causing a slowdown. I think the firewall in mention was sygate? If its not blocking the web browser it should be working fine.
I always have the opinion u should save anything u need to disk, then refomat the pc when things start playing up...
I just fromatted mine last week, and its great using a fresh system for a change :)
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
