My computer randomly shuts down for no apparent reason either.
It's either motherboard or cpu as i've i've tested everything else.
I hate pc's as it means to fix it realistically i need new RAM, motherboard, and cpu, powersuply
It never usually happens to me but I have noticed that upon new OS install it does it maybe 4-5 times then it becomes completely stable, it must be patches or something that fixes it.
I am now running 64bit winxp pro and I must say significantly quiker than vanilla xp pro.
Well i seem to of fixed my wireless woes.
I got another wireless adaptor. A linksys one.
I now get excellent signal strength and no dropouts what so ever.
Also my computer seems to boot in half the time and is more stable.
I'm guessing that the netgear wire;ess adaptor just didn't agree with my hardware and/or drivers.
Everything was up to date, including firmware on everything.
Ohh well all good now.
Also fishpaste someone from your work rang me today.
Do you guys have any games in stock at all? or is that not really your area?
someone is pulling some kinda random insurance job thing and wanted quotes on crap
have to ask the boss about games, we normally get copies of the new big titles when they come out, but other than that, we dont get much demand for them
nice score Chops
I gotta say that Im *finally* happy with my Xpertvision 2900xt 512mb from MSY Adelaide.
better performance and quality in my mind then 2x 256mb MSI 7800gtx in sli mode
.......... just awaiting my Vista Ultimate I scored for under $250 on ebay and Im set :)
LOL
hahaha oh well, atm my broadband is so bad I cant even access this webpage at home.
churning to Internode as we speak.
never mind, OEM Vista Ultimate 64-bit for 235 + delivery, guaranteed new and unopened. saw it in harvey norman for $700 odd
crazy
my current XPpro is a dodgy copy. so I guess its time to do the "right" thing
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
