time for another scandy flavoured computer related stupid question;
todays topic, browsers.
simply put, mines f**king up. constantly.
i use flock (as i tend to upload a lot of photos, and flock has a convenient batch upload function, and i just like the layout), its based on firefox, which is awesome, but recently (last week or so), if i attempt to load more than one page, or any page with video (ie, anything youtube'd) itll freeze up and 'not respond'. as you can imagine, its rather irritating having to constantly restart my browser.
and it does the same thing if i attempt to use firefox instead.
just ran a virus and ad/spyware scan which came up with nothing, and being the computer minded person that i am, im not sure if that would even affect, nor what to do next.
any ideas?
bioshock, comments?
:yawn: didnt think much of it and there was no WOW factor either
its official. my computer is mcf**ked. :3some:
who wants to build me a new one? :D
Ring Adrenalin Computers hindly street ask for Luke AKA Fishpaste he will set you up with a nice rig
lol Luke our machine is taking 20 mins to make batches so i snuk in the office or i was in the toilet on my phone i forget :P
maybe Pauly can i did see a lot of movies on it and thought it looked promising but didn't find that with playing it felt lack luster and not enough bad dudes to kill and zap
Another good one, is MOHAA - Airborne,
Try the demo, i highly recomend it.
Chops: All good here... maybe some drivers that other ppl are using arent the best for it... im using a TweaksRUs.com driver...
Edited by Pauly33GTS-t
the original Mafia was awesome just a pity no MP or they didn't release the source code so modders could finish a MP side of it
they look great its like a step back in time
i remember the original Mafia had such authentic music too was great specially when you have to get i think booze from the car park and other thugs come in and start shooting @ you when you walk through the stairs there was this great 1920's type elevator music
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
