Dont you EVER say that again! Top down or 3d GTA was and still is the best.
was the best hardly still is very few things remain the best for all time
look @ Test Drive from Accolade WAS the best but isnt now by that i mean TD 1-6 havnt played TD:U and thats more a MMO now i think
well........ Ive been saving my hard earned cash for months now, not spending on anything
been putting away onto the homeloan etc
decided to go the whole hog, so Ive bought a Coolermaster 850w Pro psu and an extra Xpertvision 2900XT to go crossfire mode with. sweeet. hahaha cant believe how stupid I am, but meh no more upgrades for a loooooooooooooonnng time (no need)
will be selling a near new 4month old SuperFlower 650w sli psu if anyone is interested, ~$100, braided lines etc etc
also, set up my basic $90 Coolermaster R120 water cooling cpu system. amazing. running my 3.8ghz cpu at 4.5ghz and it is barely "warm" sweeeeeeeeet. the radiator is like a fricken stock r33 intercooler in size !!!
coolio's. :sorcerer:
decided to go the whole hog, so Ive bought a BLAH BLAH BLAH but meh no more upgrades for a loooooooooooooonnng time (no need)
will be selling a near new 4month old BLAH BLAH BLAH, ~$100, braided lines etc etc is it for an engine bay? :pwned:
also, set up my basic $90 BLAH BLAH BLAH... the radiator is like a fricken stock r33 intercooler in size !!! more for the engine bay??
^What I get from all that :laughing-smiley-014:
(Yes I have no idea about computer speak)
lmfao !!! :laughing-smiley-014:
hahaha, funny shite
yeah, well, 2yrs ago I built a $1300 pc for me and a $2000 pc for work; I swapped them lol (only pc user at work)
recently, I pulled parts out from my home pc and sold them (got some good ca$h for parts as well, surprised) and bought brand new current-day stuff (ie video card(s), ram, cpu, sound card).
all in all this new beast is worth say $3500 but only cost me say $2000 ish (1300 + new stuff)
so Im happy :pwned:
Lol hotwire, ur a geek.
tangles you over take me with the best computer in SAU, now time for me to wait and get an Nvidia 9800 or some crap like that when its comes out, refridgeration cooling and a 1000w psu. hehe...
I got a great case, im not changing it...
hey pauley, yeah I thought about the 1000w coolermaster psu but I reckon the 850w should be fine.
couldnt justify 50% more for the purchase price for 150w of available extra power supply
the coolermaster pro 850w and 1000w psu's are six rail supplys, so that should be very stable for a top end system
if anyone is after water/liquid cooling for cpu only, Id definately recommend the coolermaster R120 water cooler. amazing value I reckon, compared to a top end copper heatsink & fan. very very loud tho !!!! :pwned:
edit: this pc has to keep me happy for a while, seeing the funds came from my awesome motorbike I had to sell
Thats why I go with the Thermaltake Bigwater 745.
double the price tho
reviews state that the R120 watercooling kit performs up there with the best
tested on a 2gig system the testers could clock by over 50%
anyway, its replacing my $75 Golden orb copper heatsink/fan unit, which Ive sold to work for $50 :pwned: so it was a $50 upgrade, lol
lol you just havnt seen the light
i had a x800xt pe from factory it was overclocked and shouldnt of been and used to get hot so i sent it back and Aust. Post lost it
so i collected $800 for insurance and looked into 7800GTX for $850 was expecting it to blow the x800 away but it didnt so i took it back for a full refund and waited and got the X1900xtx
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
