They just promised so much and I feel that it fell so short. To me there was no sense of teamplay, just some idiots running around trying to get around in a world with crap physics and poor hit detection, but hey, that's just me
Free PC sim :) BMW has got on the simulator bandwagon getting Blimey (GTR2) to make them a game for the release of the new M3
http://www.m3-challenge.com/index.php?id=2&L=0
under downloads section 354Mb
sounds are awesome mmmmm 8250RPM V8
I only have 500Mb of downoad a month... :D
anyone in the city wanna get a CD copy to me? :kiss:
99.9% of ISPs have file servers which wont attract to your 300mb limit
who are you with and we can see what they have got
LOL yep.. I just read SAU, R31skylineclub, ns.com and check emails.... Games/music etc. I usually dont bother.
Today I just signed up with 3 mobile broadband (canning home phone and adam internet) as I can get faster speed on mobile (1.5mbps) than adsl1 at my place for $30 per month. My exchange isn't ADSL2+ compatable as im on a RMX (i think thats it anyway).
Now i get a huge 1gb per month! LOL But I doubt I'll reach that very often.
are you coming tomorrow night?
if you are i will chuck it on a cd for you :w00t:
Well I was SUPPOSED to be coming tomorrow night but now I cant make it :domokun:
Do you work in/near the city at all? If not I will definately be on the cruise on the 30th
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
