NOT f**kING HAPPY!
Signed up to 3 mobile broadband as they promised d/l speeds better than my ADSL1 connection at home for a better price.
This is the result:
What a load of f**king crap. They will be getting an earful from me tomorrow
Not happy JAN!!!
Ignore speed tests they are a load of crap.
Dload from a mirror to find out your true dload speed.
That speed test reads lower than what I really dload at by approx 50-80kbytes/s.
Remember you do have a 30day trial if you like to call it that. :blink:
Yep agree with the file mirror thing, the Internode speed test even tells you to do that if you have a fast connection. 2150kb/s here
LOL @ 100m exchange on ADSL2+, too bad you need like 5 torrents going to reach that speed.
lol yeah speed tests arnt too bad an indication but definitely don't hold as gospel
[*Test Results*]
Test run on [*15/09/2007*] @ [*03:01 PM*]
Mirror: [*Telstra Bigpond*]
Data: [*9 MB*]
Test Time: [*5.25 secs*]
Your line speed is [*14.4 Mbps*] (14398 kbps).
Your download speed is [*1.76 MB/s*] (1800 KB/s)
and yes Hillzy M3 isn't easy not like Need For Speed
yeah i know i have a paid subscription to that game :)
support the community
http://www.lfsworld.net/ search Madaz_Rx8 :( thats me with no stats cause i dont play it but can if i want :laugh:
Edited by Madaz
Well, I tried my wireless here at work today (city, east side) and speeds are 800kbps and a download speed of ~70kbps.. Seems the reception is just rat shit at my house :)
So looks like I need to keep paying for line rental and ADSL1 :action-smiley-069:
Unfortunately NO. our house is on a RIM service, ie. it's multiplexed at our suburb before being taken back to the main exchange. This doesnt allow ADSL2+ unfortunatley, but we CAN get ADSL1 (which is something).
I was hoping to can home line rental ($25 per month) and land line ADSL ($40pm for same speed, $65 total) and just pay for wireless at $30 per month, to save some money.
BUT looks like the internet gods have said no LOL.
Edited by Hotwire
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
