is there anyway to force a boot from disc without going through the BIOS?
when i turn on my PC i have my 2 drives C & D (either DVD rom or 2nd HD) and can use them both fine. if i do a restart the D Drive disappears.
I have been trying to reformat but when i set the DVD rom as the priority device in the BIOS i loose it when it it exits and restarts.
its really starting to piss me off. I tried to reinstall windows from the desktop but i only have a cd with service pack 1 and my pc has service pack 2 so it won't allow me to install the older one over the top :mellow:
sorry if it is hard to follow i'm not really sure how to explain it
Edited by Whiplash
its really starting to piss me off. I tried to reinstall windows from the desktop but i only have a cd with service pack 1 and my pc has service pack 2 so it won't allow me to install the older one over the top :(
normally F8 will bring up a bios boot selection menu (not actually enteringinto bios, just gives you a choice of what to boot from). If this is a pioneer 112 dvd burner we are talking about, go get it replaced at the store you bought it from... oh also not everyone uses F8 for the boot menu, so you may need to look round at the start of the boot and see if it gives you and hint as to what they could be using
just had a go of the new Sega Rally very nice indeed and thats on a old system like mine too a while to load and only has support for keyboard but looks promising but so does the new drfit trailer for need for speed pro street
Sega Rally: Revolution 580mb GameArena DEMO
Sega Rally: Revolution 553mb Internode DEMO
New Trailer showcasing Drift on NFS:PS
NFS:PS Drift GameArena 40mb
THIS IS HIGH RES version of above
NFS:PS Drift Trailer 143mb Internode
Edited by Madaz
Can any of you tell me why this is awesome lol...
http://img138.imageshack.us/img138/9763/17102007027mb0.jpg
I get my new ASUS board today... and just as I expected. Fun fun fun...
btw, UT3 is awesome, definitely buying it.
I got MOHA, single player is great, multiplayer less so pre-patch, after 1.1 now its sorta ok, you stand a chance from snipers and sprayers in MOHA but there isnt many Aussie servers so dont buy it for the MP even tho I think its better than COD2's mp, ie less fustrating.
Edited by Pauly33GTS-t
hey chops, I actually have bought the new revision of the p5n32-e-sli board, they are build on the same Striker Extreme motherboard, with the same bios, but less cooling and a few less solid capacitors. Still kicks ass though, enjoying it so far.
CPU: Core 2 Duo E6850 3.0Ghz 4mb L2 cache 3000mhz @ ~3400mhz
Memory: 4095mb DDR2-800
Motherboard: ASUSTeK Computer INC. P5N32-E SLI
Graphics Cards Manufacturer: MSI/Nvidia
Dual NVIDIA GPUs: 2x MSI GeForce 8800GTS-OC Edition cards
Sound: Asus 7.1 Supreme FX add-on card
Hard Drive(s): C:\ (149.0 GB)|D:\ (232.9 GB)|E:\ (111.8 GB)
got parts for a 2nd pc for the wife/kids (just need screen&case)
here's mine, 3DMark06 score of 16692 http://service.futuremark.com/orb/projectd...projectType=14:
Thermaltake Soprano case
Coolermaster Realpower Pro 850w PSU
Asus P5W DH Deluxe motherboard
Coolermaster R120 cpu watercooling kit
Intel Quad Core Q6600 2.4mhz overclocked to 3.3mhz
OCZ 4x 1gb 667mhz overclocked to 732mhz
Seagate 2x 200gb Sata HD in Raid-0 configuration
Seagate 80gb Sata HD backup
ATi Xpertvision 2x 2900XT 512mb pci-e dx10 graphics cards in Crossfire mode
Creative X-Fi Fatality Pro XtremeGamer soundcard
Zalman 5.1 6ch headset & mic, Solman 5.1 6ch sub/speakers
Logitch G5 mouse, G15 keyboard
Cmv 19” LCD screen
LG Dvd-Rw, Sony 1.44 Fdd
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
