I think you're still looking around the 1100 - 1300 dollar mark.
I get the feeling though that some time in the future sony may release a fully software emulation of the ps2 hardware for ps3. And then you won't need to get a 60gig. Thats just a bit of an eduated guess.
so its true you cant play ps2 games on a 40gb ps3 :rofl: i thought that sounded fishy but hey we are talking about sony
i got a feeling a chip is on the way letting u play copied/downloaded games as well as PS2 games...maybe more :yes:
query:
Q6600 @ 3.60 ghz (2.4 stock) G0 stepping model
2900xt (two-off) with coolermaster glacier-600 water cooling
thermaltake bigwater 735
70degrees core 0, 69 core 1, 67 core 2, 66 core 3
on full load
is that too hot?
bearing in mind the graphics cards idle at 49degrees
runs at 47-44deg on idle
pump - cpu - pcie - pcie - radiator - reservoir - pump
had a nth bridge water block as well, but not on atm
might have to refit it along with the double radiator - just that the extra radiator has to sit outside the case :)
Yeah man that is WAY too hot for a water cooling system. I would turn your voltage down a tad - but you may have to lower your fsb too. What voltage are you currently running? I would think around 3.8v, which is probably too hot. Your CPU won't have too longer life at that rate. 44 degrees is way too hot at idle too.
Should not even be that hot with a really good heatsink and fan.
Put more case fans in and get more air flow will cool it down heaps. I have 2 x intake and 2 x outlet fans, plus the CPU, VGA card and dual PSU fans. There is no such things as too much air movement. Is the fan working properly on your radiator? I think it may not be - that would be your problem.
yeah thought so
better rejig it and add the external double radiator/fan system (its a 745 system, but only setup the small single radiator)
the 2900xt's used to see 100degrees on air (stock) on load, so the water has brought them down by 35degrees
    • Heres another fitment photo. redrilled the pattern to 5x112, and threw my audi´s rims on. had to touch the upper control arms with grinder, because the "sharp corner" was sticking about 2-3mm on the tire path. i have the "fender lip" mostly cut off, otherwise these (too) would contact with it. 20x9.5 ET25 rear    265/30 20x8.5 ET20 front    255/30 they are temporary, and look too big for the chassis. searching for 19s to it.
    • From experience, it will come back to bite you haha.
    • Background: my BMW 225i hatchback (rebodied MINI/X1) came with 3x RE003 and 1x Goodyear Asymmetric something. The RE003 roared and slid around, the Goodyear side was quiet and grippy. Definitely my car was thrashed before it got sent to dealers. My brother also got RE003 all round on his old VA WRX STI, I wasn't impressed with them, car was loud so can't comment on noise. Anyway, Hankook stopped making/updating V12 Evo2. So bought S1 Evo3 runflats. Great daily duties tyre and not that harsh ride. Tyre reviews site/youtube rated them as best stopping in the rain and I believe them. Next set, Goodyear Asymmetric 5 non-RFT. It beat PS4 in tests and is like $100 cheaper, so put them on. Great tyre, more grip then S1 Evo3 but a tad noisier as expected, still rocking them. Next set I am looking to go runflats, probably the new Hankook Evo. Although the new Pirelli PZ5 did well in tyrereviews test. Or go Goodyear Asymmetric 6 which was top tyre last year. The V12 Evo2 on my gen5 Liberty GT wagon did great in cold condition (drove to snowy mountains for a day so my husky can feel his ancestor's roots). Super impressive performance for $120 each lol. Never skimp on tyres, brakes, suspension. There's old pics of my R31's crappy random brake pads bending in the caliper at Oran Park track day somewhere around here. Anyway, my 2 cents.
    • I said "Matlab clone". I could throw one onto one of my linux VMs. Probably only take 10 or 20 hours to sort out the dependencies, relearn how to use it, etc etc.
