does anyone know how to setup a mic? my mic was working fine until i did something and it ferkd it up, so now weneva i record or talk over the mic everyone can hear what im hearing through my headphones when they shouldnt be. help please >.<
yeah I wouldnt bother with quad cards. but two in sli would be nice.
jsut want to play crysis with nice frame rates.
call of duty already looks nice on the 8600gt. but It would look alot better with high resolution.
Almost better off selling the 8600gt and buying one 8800gt as one 8800gt kicks an sli 8600gt setup.
all the nohaxnetwork servers are good
my name is MR.MADAz
you can find me in NohaxNetworks Ventrilo
IP: 144.140.154.69 PORT: 3875
you will need to right click my name and send user page and i will hear you
i also play alot of SOF2 on PTGN Perth
i use the Arena to find my games :( i have Xfire but dont use it
my name is MR.MADAz
cool.
Been playin it on ps3 alot.
just started online with the pc. So alittle shit.
Will see you on there im sure.
I've played a bit of COD4. usually on the Internode servers. Apart from getting my arse handed to me they appear to be fine.
Recently bought a 22" samsung and the ol' 8600GT is struggling a tad at 1680x1050. Still does 'ok' though doesn't completely fall to its knees.
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
