I have the following for sale:
1) R33 GTST series 1 front + rear seats (very good condition) front = $70each/rear = $70
2) R33 GTST factory front + rear shocks with springs (not sure on condition)- $100
3) R33 GTST low sitting King Springs (good cond i never used them) - $100
4) 6 Apexi 555cc injectors for R33 GTST. 1 is not working may need service or the like - $600
5) R33 GTST series 1 original cams - $200
6) Tomei adjustable cam gear (brand new) - $250
7) R33 GTST series 1 steering wheel - $30
8) R33 GTST series 1 factory computer - $100
9) R33 GTST factory plenum (top + bottom) - $70
10) R33 GTST original Nissan plenum gasket (not used in plastic) - $80
11) R33 GTST series 1 coilpacks - $20 each
12) R33 GTST factory intercooler (good condition) - $50
13) XF throttle body - $50
14) R33 GTST front + rear doort trims (good condition) - $30 each
15) R33 GTST factory boost solenoid - $20
all items are negotiable. want to get rid of them asap.
https://www.sau.com.au/forums/topic/108829-r33-parts/
The coil packs have around 90,000kms on them. I changed to splitfires as i was intending to run 20psi boost or more. not sure on condition. i dont know how to check but you are welcome to.
ActionDan i sent you a PM. did you get it?
ill post pics up tonight..
https://www.sau.com.au/forums/topic/108829-r33-parts/#findComment-2005818
sorry ActionDan wrong person. i have some guy wanting the springs. not sure on the part number. they are the genuine nissan item. if you call nissan im sure they can help you but i have no idea when it comes to suspension.
https://www.sau.com.au/forums/topic/108829-r33-parts/#findComment-2005825
3) R33 GTST low sitting King Springs (good cond i never used them) <--- how can that be a genuine nissan item?
THOUGHT U WERE AFTER THE STABDARD SPRINGS/SHOCKS. THE KING SPRINGS ARE NOT STANDARD BUT ARE THE SUPER LOWS FROM MEMORY? FROM WHAT THE GUY TOLD ME THE RIDE HEIGHT IS 45MM LOWER THAN FACTORY WITH THEM. I DONT KNOW ALL THE DETAILS JUST BOUGHT THEM AS A TEMPORY SOLUTION FOR THE FACTORY SPRINGS BUT NEVER GOT THEM ON.
https://www.sau.com.au/forums/topic/108829-r33-parts/#findComment-2006156
hey mate, do you have a number i can ring? if you want, give me a bell or send me a msg on 0413 032 208
Im interested in you intake plenum and your XF TB. O, and i live in south coogee, so nice and close for pickup :D (btw, what car do you drive? mighta seen you around? )
-Tom
https://www.sau.com.au/forums/topic/108829-r33-parts/#findComment-2006782
Im interested in you intake plenum and your XF TB. O, and i live in south coogee, so nice and close for pickup ;) (btw, what car do you drive? mighta seen you around? )
-Tom
Anyone can call me on the following number. 0410 580 010. i work weekdays from 9to5.30 so if i dont get the phone until then just send me a text. Cheers
Boro..
https://www.sau.com.au/forums/topic/108829-r33-parts/#findComment-2007656
Croat,
PM sent. Want to buy the steering wheel, item number 7:
"7) R33 GTST series 1 steering wheel - $30"
Let me know your reply at [email protected], or alternatively SMS me on my Vodafone prepaid number: 0406 047 490.
Much appreciated,
rav4lution
https://www.sau.com.au/forums/topic/108829-r33-parts/#findComment-2016407
