I have the following for sale:
1) R33 GTST series 1 front + rear seats (very good condition) front = $70each/rear = $70
2) R33 GTST factory front + rear shocks with springs (not sure on condition)- $100
3) R33 GTST low sitting King Springs (good cond i never used them) - $100
4) 6 Apexi 555cc injectors for R33 GTST. 1 is not working may need service or the like - $600
5) R33 GTST series 1 original cams - $200
6) Tomei adjustable cam gear (brand new) - $250
7) R33 GTST series 1 steering wheel - $30
8) R33 GTST series 1 factory computer - $100
9) R33 GTST factory plenum (top + bottom) - $70
10) R33 GTST original Nissan plenum gasket (not used in plastic) - $80
11) R33 GTST series 1 coilpacks - $20 each
12) R33 GTST factory intercooler (good condition) - $50
13) XF throttle body - $50
14) R33 GTST front + rear doort trims (good condition) - $30 each
15) R33 GTST factory boost solenoid - $20
all items are negotiable. want to get rid of them asap.
https://www.sau.com.au/forums/topic/108829-r33-parts/
The coil packs have around 90,000kms on them. I changed to splitfires as i was intending to run 20psi boost or more. not sure on condition. i dont know how to check but you are welcome to.
ActionDan i sent you a PM. did you get it?
ill post pics up tonight..
https://www.sau.com.au/forums/topic/108829-r33-parts/#findComment-2005818
sorry ActionDan wrong person. i have some guy wanting the springs. not sure on the part number. they are the genuine nissan item. if you call nissan im sure they can help you but i have no idea when it comes to suspension.
https://www.sau.com.au/forums/topic/108829-r33-parts/#findComment-2005825
3) R33 GTST low sitting King Springs (good cond i never used them) <--- how can that be a genuine nissan item?
THOUGHT U WERE AFTER THE STABDARD SPRINGS/SHOCKS. THE KING SPRINGS ARE NOT STANDARD BUT ARE THE SUPER LOWS FROM MEMORY? FROM WHAT THE GUY TOLD ME THE RIDE HEIGHT IS 45MM LOWER THAN FACTORY WITH THEM. I DONT KNOW ALL THE DETAILS JUST BOUGHT THEM AS A TEMPORY SOLUTION FOR THE FACTORY SPRINGS BUT NEVER GOT THEM ON.
https://www.sau.com.au/forums/topic/108829-r33-parts/#findComment-2006156
hey mate, do you have a number i can ring? if you want, give me a bell or send me a msg on 0413 032 208
Im interested in you intake plenum and your XF TB. O, and i live in south coogee, so nice and close for pickup :D (btw, what car do you drive? mighta seen you around? )
-Tom
https://www.sau.com.au/forums/topic/108829-r33-parts/#findComment-2006782
Im interested in you intake plenum and your XF TB. O, and i live in south coogee, so nice and close for pickup ;) (btw, what car do you drive? mighta seen you around? )
-Tom
Anyone can call me on the following number. 0410 580 010. i work weekdays from 9to5.30 so if i dont get the phone until then just send me a text. Cheers
Boro..
https://www.sau.com.au/forums/topic/108829-r33-parts/#findComment-2007656
Croat,
PM sent. Want to buy the steering wheel, item number 7:
"7) R33 GTST series 1 steering wheel - $30"
Let me know your reply at [email protected], or alternatively SMS me on my Vodafone prepaid number: 0406 047 490.
Much appreciated,
rav4lution
https://www.sau.com.au/forums/topic/108829-r33-parts/#findComment-2016407
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
    • C'mon! At least come kicking and screaming into the 2000s. BA XR8 bulge.
    • No such thing as E30 in Sydney servos As stated above, flex fuel is your only viable,  and "safe" option I believe
