As I havent started my car over the past 4-5 days, the battary has gone completely flat. I even tried turning to headlights on to which, not a spec of light came out of it.
However, I jump started the car to which everything is working perfectly fine.
HOWEVER!
When reading the digital read out of my RPM on the AVC-R, it's actually sitting around the 150-200rpm mark but on the rpm guage on the dash, its readying correctly at around the 800rpm makr.
The RPM read out on the AVC-R was working perfectly fine and reading correctly before the battary was completely dead.
Anyone got any ideas?
https://www.sau.com.au/forums/topic/108852-avc-r-rpm-readout-issue/
in car select make sure u have the speed set to number 2 in settings. I had problems with this making my speed readout weird
ok, might explain it a bit then.
i currently got mine set to 6cyl, 4spd.
even the rpm is now reading at around 150-200rpm when on idle.
to which is wrong cause on the powerfc hand controller, it reads correctly due to whats being shown on the analog dial on the dash board.
there is an option to select how many times it outputs at ...and you can shoose 2pt , 4pt 8, 16 etc...change it to 2 and see if it reads correctly.
i adjusted mine to a higher setting and i got incorrect readings, so this is what i done
