for the last 6 months ive had a 2535 on my series 1 rb25 running 15psi and putting out 231kw.
the car is punchy and makes full boost by 3200rpm but i want it to feel more aggressive and come on boost more rapidly and maybe earlier. (it feels like a vtec, very safe tune)
I think these are my options:
*bigger 550cc injectors and run a more aggresive tune
*exhaust cam gear
*split dump pipe
does anyone else have any ideas how i can make my car more aggressive out of the corners?
I'm a sook, i cant handle any lag
https://www.sau.com.au/forums/topic/108919-hitting-boost-quicker/
Hahah 2535 Lag?
I loved the 2535 on my RB25, it hauled ass!
I don't know about yours but mine came on boost very suddenly and sharply!
I had EBC, Split dump, FMIC and SAFC-II :P
ps I would go for the split dump - while running stock dump with my 2535 it was woeful! - Best $$$ spent was on Split dump
Seems to be a recurring theme with the rb20 and rb25, this lag problem.
With how cheap turbos and exhaust manifolds are getting nowadays, I wonder if a twin turbo kit could be mass produced with two tiny turbos to virtually eliminate all lag.
Just a thought.
3inch turbo back exhaust, split dump setup
aftermarket engine management (powerfc)
injectors wont help at all
a pair of tomei cam's
a good cold air intake
make sure you dont have a big stupid 800x400 FMIC
ive already tuned the first 8X8 cells in a very similar fashion, it made a difference to economy and the transition between off-boost and coming on.
that table u have displayed paulr33 looks like the stock ignition table??
will an exhaust cam gear make the mid range much more punchy???
Edited by reflex
well if you've done the ign timing then theres probably not a great deal more you can do. i dont think cam gears will give you 2 tenths of fark all. yeah i posted the stock ign table to see if you were still running that (some tuners don't touch the low area).
wind that boost up!!!!! you wont even have time to look at the tacho if you wind about 17 - 18psi into the 2535... the difference on mine was amazing from 14 psi to 18psi....
The power was very smooth and progressive before but now you can feel a strong surge of power then BANG!!! she pulls and pulls!! i love it!
if your in my area, ill take you for a spin if you like or if your at then next vic event??
If your wastegate was opening at idle, would explain why you're disappointed with power output!
My suggestion, after reading that comment, is to take ur ride to a mechanic and get it fully inspected, to make sure everything is running right. No use flogging a dead horse.
a good way to see if thats the case or not is to
unplug the actuator line and do a dyno run (be sure to watch boost) and immediately back off when target boost is reached, cos you will be in unlimited boost mode.
then do another dyno run with the actuator connected again like normal and let it run. then overlay the two dyno runs plotting only boost and see if they are the same. if they arent then the actuator is leaking or opening too early
    • Are these a plug and play setup, and do they need a tune, like a haltech ecu etc? Thanks
    • Nice work on the paint. Those 3 studs are long as.
    • Hi everyone, still chasing a bunch of this stuff. Thanks
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
    • I'm 22 years younger than you mark, and I'm operating in the exact same way! Ha ha ha
