Electronics/scanner Dudes? (<---weird Title)
heya blokes
weird question
moving into a new place and they gave us 1 swipecard for the building... its one of those big swipecards, you know... like a big thick playing card.
they say i have to pay a $100 deposit to get another one which is fair enough.
what i wanna know is, is there someone around sydney that can scan the code into a smaller card/chip sort of a thing that can be chucked on a keyring, if i gotta pay i'd rather have something not so cumbersome
i'm sure there are people who do this sort of thing with the way of computers and machines nowadays, just dont know where to start loooking...
cheers
Jimbo :D
https://www.sau.com.au/forums/topic/108925-electronicsscanner-dudes/
i have those huge credit card sized ones in my building. all senior staff were given the option to upgrade to a little keychain one. so now using that one i must say it's great. it's about 3cm long and 1.5 wide and thick. for my other bulding i have one thats about 4cm long and 3 wide. it's not bad either, but the other HID systems one (super small one) is better.
hmm, well when i got my new one the building manager dudes have a little machine that codes the tags. i'm pretty sure the brand of the stuff was HID systems.
ok, it was site is: http://www.hidcorp.com/pr_detail.php?id=140
now you just need to find somone with the euipment, or contact their sydney distributor and ask if you can buy one of the small cards, then give the old and new one to your property manager and get it coded.
the pass i got was this one (instead of the old card sized ones):
Hey Jimbo,
I'll need more details but this is my specialty!!!
1. Do you know what type of proximity card (any labeling on the card or the reader). Need to work out what type or card it is first.
2. Once we establish what it is i need to get my hands on it to verify the data getting a duplicate is not usually a problem.
Cheers
Mick
heya blokes
weird question
cheers
Jimbo ;)
I think you'll find you actually have to 'teach' the system the code of your key, not the other way around.
They just work by having a liffle tuned circuit that oscillates at a given (precise) frequency.
Edited by Mik
Normally you would need to add new cards to the system but if you have one working i can get duplicates so the system will not know the differencet.
It all depends on the 'card type' - but i can do most of the common ones....
Key chain ones cost a little more but can easily be done :D
Not to scare anyone off.. Im no building theif, and i don't want to know what building its for..... I am an engineer for an australian building access control system developing company. We/I have developed a system that reads almost all readers on the market. When contracts are won for buildings existing cards are usually sent to me to verify what type they are.... so if you ever need to get duplicates (for your own personal use) i can usually find out what they are encoded with and get them for you...
Cost of $100 a card make me laught as the trade price is usually $2-5 dollars each. :)
Edited by Kero
Its no HID card...
Its almost certainly a e5550 based card (which is even better -as ive got shit loads of them and they are easy to copy)
They are used on PRX, UtraProx and Sirus card readers.
I can give you the same cards or if you want something smaller ive got a proximity dot. (Its a small little dish about 12mm in diameter.
I have mine stuck on the side of my car key or i can put it on a keyfob (as shown below) to go on your keyring.
find better image and insert here...
Just need to get it to me and and ill double check what the card is, but im 99% confidant i can do that one. And as i have plenty of those ill do it for FREE in what ever combo -(card, dot, dot on fob).
Cheers
Kero
Edited by Kero
Its no HID card...
Cheers
Kero
thats sweet as man!!
can you do anything like the one pictured above by richard?
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
