ok specs 4 the amp r
output power max 200x2 channel
out put power (bridged max) 400x1 channel
low pass filter – 40Hz to 1.50 Hz
high power filter – 80Hz – 1.2Hz
Frequency response – 5Hz to 50kHz
Signal to noise ratio - >95dB
Stereo Separation - >60dB
Input sensetivity – 200mV to 2V
Input impededance – 10Kohm
Fuse rating –15A
Overload, thermal and short circuit protection
Inbuilt crossovers
Bridgeable and tri-mode
2 channel
features
class “AB” technology MOSFET PWM power supply
bridgeable and tri-mode operation
continuously variable 12dB/octave High power crossover
continuously variable 12dB/octave low power crossover
enhanced bass boost 0dB/+6dB/+12dB @50Hz
gold plated RCA, power & speaker terminals
soft start and muting
overload, thermal & short circuit Protection
Blue Bar LED power and Protection indicator
Stable into 2 ohms
Adjustable input gain control
https://www.sau.com.au/forums/topic/10893-12-mtx-sub/#findComment-205432
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
