i read for the R33 when i had mine, that the fuel light came on when there was approximately 7L left in the tank. one could assume the same for the stagea. i've driven for up to half an hour on my fuel light and not had a problem. helps to squeeze that little extra out of a tank
  • Replies 216
i never really bother. Under 1/4 and i fill up.
When installing the fuel pump, i was told the fuel tank design is different in the stagea in that there is a little "pocket" in which the fuel pump sits, meaning it is 100% the lowest point in the tank.
Ive driven around 2 days (~50km) with the light on and my 040 was still able to suck fuel up
couldnt agree more tangles
i filled up $91 the other day.... 66L... yepp... I KNOW ITS A 65L tank :D
Dunno how many litres but $68 for 98/10 from when the light came on.
Currently using 15or16/100.
Would like toget a kickback from AWB.
ok, first re-fill, some very varied driving including some babying (while I had an exhaust manifold leak that sounded scary) some highway cruise, on most drives I managed give it a poke in the guts once or twice, and one rip through a very twisty section of the Ocean Road late one night mid week after I fixed that manifold leak...
390km/51Litres
~13L/100KM
Not bad, I think it could do all right on a long open road trip, filled up with a bit under 1/4 of a tank and got the 51 Litres in so there was ~15L left if it is a 66L tank, that would have been close to 500km to a tank, that sounds all right to me.
I try to fill up around the 1/4 tank mark as it doesn't hurt so much, just more often I guess...
Cheers
Luke
revving on the hwy is the fuel comsumption killer
its cycling through the load axis on the fuel map that waste's fuel.
as soon as you open any decent amount of throttle it will drop on the load map on the stock ecu and the afr's will richen up too all hell, which is where the economy goes out the window
if you do a full tank of 100km/h driving with a steady throttle you'll get some kick ass economy, assuming the narrow band sensor and 02 feedback is working correctly
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
    • These arrived today! Sadly I'm going to probably be smart and enjoy the car as is over the summer/sunny period and save the ~2 weeks downtime it'd take to swap the heads over and tune later in the year. Maybe. It's going to be pretty damn tempting seeing these bolt on funs just sitting in storage when they're ready to go. There's a non-zero chance I end up @The Bogan'ing it.
    • MZ11 Toyota Soarer in Iwata, Higashi Osaka
