  • Replies 216
well ive gone through just over half a tank after changing the O2 sensor and fuel economy seems to be unchanged, i will be changing the air filter to a K&N equivalent panel filter, perhaps that may make a difference.
im running out of ideas, ive already changed O2 Sensor, fuel filter, used injector cleaner.
anybody have some other ideas?
Had the same problem but have not actually got around to changing my 02 sensor, its still just unplugged at the moment. Mileage went up by about 80kms per $60 of petrol though. Not sure whether it will get better or worse when I plug it back in with the new one. Before I unplugged it it was running so rich I'm sure there was raw fuel coming out the back end :dry:
Lead foot does play a big part though. Drove from Hamilton to Auckland (about 80km) like a Nana then drove a 3rd of the way back (about 25km) at 120km/h & I had used about twice as much gas as I did for the whole distance of the original trip. Went back to driving like a Nana for the remaining 55kms.
Edited by tRUkbOY
my latest tank yielded 263.6km for 61.06L thats 23.16L/100Km
...thats rediculous!
i admit that i gave it a bit of stick on this tank of fuel, however its starting to be beyond a joke, when you consider the car is mostly standard.
it seems to be getting progressively worse as each tank passes, so im leaning towards the problem being with the airflow meter.
i'll try and get it checked/replaced soon to see if its the problem. anyone got an idea of what they are worth?
agreed - get a Z32 afm. There was a group buy recently for around $300.
or 2ndhand ones are around the $200 mark, same for a Q45 afm.
both q45 and z32 'read' more than a standard rb25afm..............
then tune the a/f ratios with a SAFC and you'll get better mileage!
my mileage has gone down hill big time, using 15kms more per 1/4 tank, since I intsalled the free flowing CAI box. I need a retune of the SAFC but its too damn expensive........ need to save up for the bigarsed turbo first!
well i bought the standard AFM from wolverine (cheers heaps for that Andrew) and ive fitted it to my stag.
i noticed straight away that the small amount of backfiring i used to have, has ceased, so hopefully it will answer my fuel economy crisis.
I went and filled up my tank at the servo and reset the trip odometer, so i'll let you guys know the outcome.
I switched from my 19's to 16's a couple of weeks ago, as decided to get new rims.
Anyway in the last 3 week's l've been getting about 75km's more a tank than l was when l had the 19's, which surprised me that it made that much of a difference.
Getting 18's next week ... hopefully it won't change too much with them.
WOOHOO!!!
after replacing my AFM with the second hand one that i bought from wolverine, my fuel consumption has gone from 23L/100Kms to 14.3L/100Kms
the backfiring did come back, so a tune with the DFA will increase it even more. ill probably get it done once ive finished my exhaust
>_<:D:D:(:):D:D:D:D
To increase my fuel ecconomy I went out & bought a little N13 pulsar!!! Now instead of spending $80 per week on fuel just to go to & from work, it now costs me $70 per f/n to fuel both cars!!! I figure it'll take about 3 months for the pulsar to pay for itself in fuel & then i'll be saving $$$. (not bad for a $500 car!!!!!)
Plus i get the bonus of not clocking the km's up on the stagea!
If you knew a Stagea was only going to give you 15l/100k would you buy one. If the answer is NO, then you dont deserve a Stagea!
You gotta love Nissans to buy one. Fuel consumption is the last priority on the list.
But after you doget one, S1 or S2, there are many ways to improve fuel consumption.
At the moment I am building a Jaycar DFA,a Smart Fuel mixture Display and a Hand Controller.
Thats the first step, and I'll keep an eye on the O2 sensor and the A/F sensor.
I'll keep you posted.
thats it mate, i just enjoy the drive these days and just accept the cost. Its completely worth it. FFS 15L isnt THAT bad really.
My mates dad's 550 maranello has a 110L tank and drinks 2 of those a week when it was a street car (work and back + some fun)
I've had the DFA in the car for a year now, and it still pops when you pull back into second gear on the overrun (that is probably the 3 inch exhaust working there).
In any case, just reporting in that I got to drive the thing (an old series 1 stag with auto) for a full tank on the highway, down to the goldcoast and back, then up to the sunshine coast and back to Brisbane, then back up to Bribie last week. With the mods as mentioned in post 58 of this thread, it went 583 km before the light went on. When I filled it back up, it took 58 Litres of BP ultimate. Result ! thats 9.95 L per 100 km. whohoooo, into the 9's !
The thing is tuned lean at cruise (15.5: 1 air fuel ratio) using the DFA and a wide band O2 sensor, no need to take it to a dyno shop for the tune, with the wide band in the car, you tune it as you drive. I know its supposed to cruise at 14.7: 1 in closed loop, but there must be a limit to the amount of trim the computer pulls back into the cruise mixture over time, so if you monitor the fuel ratios every month or so with the wide band, you can see at the start the computer tries to put fuel back in, but after pulling fuel out again the second or third time, the computer must run out of trim in the cruise load zones, thus I can happily cruise at 15.5 to even 16:1 and get an additional 8-10% fuel economy. It is a little doughy at cruise, but the additional ignition advance which comes in at the same time when tuning with the DFA helps there.
The clincher has been the revised valve body in the auto, which helps it hold onto the lockup on the converter longer, and also the fact that it seems to get 5- 8% better fuel economy when running on BP ultimate compared when it runs on optimax. Dunno why, obviously ultimate is a different fuel composition, but it certainly gets better mileage on BP ultimate.
Anyways boys, try to beat that on the highway and get yours into the 9's.....
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
