  • Replies 216
I usually use bp ultimate and got about 400km per tank
But i changed to a k&n filter, 3in turbo back and upped the boost to about 10 psi.(about two weeks ago)
I am now getting about 460-500 per tank (red light for the last 30km)
Everything stock except the above, still using bp ultimate..
I have found in the past that caltex/woolies petrol never gave me as much k's
96 rs4, btw
OK ..... I'll bite.
What's wrong with Mobil?
Had a very expensive experience with my old R31 when I was using Synergy 8000.
Got a bad batch (I guess) and it seized up the car. Turns out everything from the pump to the injectors needed replacing.
The mechanic said it was like someone had put glue on my tank (not possible as the sputtering only started after I filled up on the way to work that day).
It is probably a fine fuel now, but you know how it goes.
Hard to quantify. Last tank gave me 12.5 l / 100, previously its been more like 15. 570 ks per tank vs 450
As I said, I'm trying the 2nd tank now.
As to power, this is seat of the pants stuff. I'm comparing with my 200kw ATW zxtt. Still not as fast, but noticeably better than it was.
m
hmmm, interesting.
I know it is impossible to replicate exactly, but are you roughly traveling the same route & similar speeds as with the previous tanks?
Need to fill up today... Might give it a go.
As an aside, are there any RS or RX owners getting the 15L/100 mileage that the AR-x owners are getting?
I only ask because I have never travelled less than 615kms from full to when the light comes on.
Even with the exhaust and 1bar max boost I am still getting 630-640kms.
Could the Ar-x be thirstier than an RS/RX?
i pulled the top off the tank one day . the fuel light had come on with in a k of home . we all know how big the tank is . about 3 foot wide and 2 foot long (roughly) (ish) and there was at least 5 inches of fuel in there .
the guy that said it caught him out did it stop while you were driving or would it not start after you parked somewhere . coz as we all know it makes a huge diff if the car is parked on an angle
114.5 :) who cares what they use at this price
That's if your being tight and putting in normal unleaded (has anyone put normal unleaded if so, how does it run). I normally use either 95 (BP 95 Unleaded or Synergy 5000) or 98 (Ulitmate or Synergy 8000) roughly get around 430 - 440 per tank but I haven't ran the tank to light goes on for a while
Edited by BigDirtyJase
mobil or BP 98 :D
i just use the normal ULP price as a reference point as i am sure many others do- its on the big signs when driving past :P
  • 1 month later...
Well I'll be damned... I've had the last week off work and managed 11.9L/100km in one tank with the occasional boost but otherwise very wary of being light footed. Usually the mrs drives it 5-6 days a week and I get 13.5-14L/100km. What a difference the driver makes!
hmmm, interesting.
Interesting.
Remember that the only cat I have is on the dump, my front pipe has deleted the large cat.
I filled 2 tanks with Vortex98 and let me tell you, my car reeked on rotten eggs, my mate told me that I blew a puff of black smoke when changing gears on high boost and I got ~20km's less for each tank.
After having the next 2 tanks filled with Ultimate, no more smells or black puffs & my economy is back to 620-640km's until the light comes on.
My last 2 tanks have been of Vpower & have been the same as with Ultimate.
I guess that Vortex is a dirtier fuel after all. :cheers:
My trip to work is quite short. At other times I am usually adjusting something like now when I am fine tuning my boost controller (foot flat much of the time) to suit my new turbo so I am getting about 20L per 100km or just over 300k per tank. The best I have ever had is about 13L per 100k ( about 420km per tank). I am stopping spending money on my engine when I install my adjustable exhaust cam gear and then I am going to the top tuner in town and hope to get 200 - 220 AWKW with absolutely smooth acceleration and better fuel consumption when touring.
I am using E10 fuel and i have always figured that the highest octane fuel doesn't cost more because it is more efficient. the standard ecu will adjust for different octanes but it always runs too rich at the top end. For those with computers or other fuel control devices these are usually set to a particular fuel so it doesn't pay to chop and change.
2000 model, stock standard Stagea Type S;
Averaging 420-450km to a tank around town.
Got 9.6L/100km on the Hume Hwy to Sydney last month.
That sound about right? I thought the highway consumption was not too bad (still pretty dodgey around town though ). :(
Stageas are heavy gas guzzlers. Your figures are very good.
Standard s2 rs4v
12.5 - 13.5L/100 - fast country driving running 95vortex
20L/100 - running reg. unleaded :(
I always thought running 91ron and 95ron fuel was not very good for a 98ron car? Seems to be a few people running 95ron in their stags.
Some servos are still pretty dodgy. Some I have been to in tne sticks sell 95 at 98 price Some dont even know which Ron it.
Im still in the 15/16 rut. The hills are fun to drive so I cant complain. Got some real Vortex for 101.9 last week.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
