How long is the piece of string?
What turbo?
What state if the motor in?
looong list
Anyone can put a big turbo on and make 500rwkw.
Doesnt mean you can call that motor reliable
Yeh I know its a preety vauge qeustion Im sourceing a new engine taking my time so it will be a good condition engine, for my 33 GTST and stocking up on goodies to add on in the mean time all I want to know is whats the biggest turbo you can use if you change to sard injectors,N1oil pump,N1water pump, high mount manifold, metal head gasket,FMIC,radiator breather,air flow meter,oil cooler,oil catch can,powerfc with boost controller,fuel regulator,bosch fuel pump,BTMBL split front dump and 3" zorst etc etc... but leave the internals stock?
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007246
your plan is very flawed and lacks some important parts;
1) how much do you have to spend
2) what is the car being built for
3) what is your power goal
no need for n1 water pump unless going on a race track all the time (its not suited for street)
no need for n1 oil unless going on a race track all the time (its not suited for street)
high mount manifold is useless
what airflow meter?
why sard injectors?
what clutch?
what cold air intake?
without knowing anything else its very hard to tell you what parts etc.
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007260
what airflow meter?
why sard injectors?
what clutch?
As youve more than likely allready figured out im pretty new to all this and since im putting in a new engine I just thought Id buy new everything so just went on just jap and nismo and started listing parts and thought might aswell buy the best, what power can you safely push an unopened rb25det to?
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007279
After buying the engine and getting it in i was looking at spending 6-7k but not in any hurry thats why im on here asking questions, im not planning on draging/drifting or raceing anytime soon I just want a quik car with a nice kw rating something thatll show my mates up in there clubsports and XRs :laugh:
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007285
max power of stock internals is around 270rwkw
any more and your starting to risk safety
What mods would you suggest to push it up to around that, thats the kind of figure I was hoping for but didnt really want to have to rebuild
ps-thanks for this mate lotta blokes just get on here and treat us newbs like idiots
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007289
rb25det
+ heavy duty clutch $1200 fitted
+ apexi powerfc + boost kit $1500 tuned
+ nismo 550cc injectors $1000 fitted
+ z32 airflow meter $450 fitted
+ gtr33 fmic $1000 fitted with pipework
+ 3" turbo back batbml exhaust and 3" hiflow cat $1500 fitted
+ good cold air intake $400 fitted
+ gtr33 fuel pump $300 fitted
+ hks gt-rs $2800 fitted
+ nismo fuel regulator $300 fitted
+ set of good 255 tyres $500 fitted
total; $10,650 with conservative labour rates
then you should really look at brake and suspension upgrades.
with that amount of power, estimated 260rwkw at 1.3bar it will spin and carry on sideways and insist on spinning as much as it can so you really need to work on the suspension to make it more enjoyable, safe and allow it the best chance to get the power down.
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007299
' date='10 Mar 2006, 12:11 AM' post='2007280']
hey dude :laugh:
why are you buying a new engine what is wrong with the current one in ur r33 now?
looks like when I had it serviced some cock jockey forgot to screw the plugs back in, drove fine for about a month and them blew the thread out of no1 burnt the coils and dropped who nows what into the engine, I could pull the head off get it machined put in a hellicoil and put it all back together again but whos to say thats the only problem and then Ive spent more than half the money Id pay for a whole engine replacement so I though wtf not? first I was thinking of the 25/30 build but thats out of budget for me :laugh:
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007305
Manifold - $1200
ECU - $1100-$1800
Tuning - $400
Turbo - $1800
Injectors - $900
AFM (maybe) - $350
Ext Gate (maybe) - $700
I/C + Piping - $600
Radiator - $660
Fuel Pump - $300
FPR (not needed) - $150
Catch Can - $250
Exhaust - $700-$1100
Your well over the 6-7k budget dude. You at 9k before you even start paying for labour which will put you into the 11k or more region
Those prices are retail.
I think your best bet is to settle with a stock turbo for the time being.
Get all the bits save for the turbo/injectors etc etc as you are double your budget before you even start.
Who cares about showing off to your mates. Going from 150rwkw to 270rwkw isnt a walk in the park. Can be the death of you quite easily
1) Have a read of the RB25 sticky thread
2) Have a search on the turbos used (for more detailed threads) and then go from there.
3) All this has been done pretty well before as 250rwkw is common goals.
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007306
rb25det
.got the exedy heavy clutch in allready,BTMBL and 3"exhaust within the fortnight, the sard injectors are 550cc nismo better?FMIC next week,powerfc and boost control about a month, think I can get the turbo bit cheaper than that through someone,where could I get cold air intake/fuel pump/airflow meter?
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007312
hey i just add my 2cents, i just bought this stuff for my rb25
-hks gt2835 pro s kit (400ps) - $3500
-Nismo 740cc Injectors - $1000
-Apexi Pfc - $1000
-Z32 AFM - $300
=$5700
i already have ebc,fuelpump,clutch,coilovers,clutch etc etc
then you got to add labour etc etc...
6-7k = not going to get you much :S
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007320
For SARD - search, the problems with the RB25 fuel rail are well documented by everyone who's tried using them ;)
end of the day, dont get em
im running sard 550cc's and had no issues with them ..
can be more tricky to install.. but once in correctly,. no issues
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007425
I just want a quik car with a nice kw rating something thatll show my mates up in there clubsports and XRs :)
:P
Not another one!!!!
I know a cheaper way mate.
spend some of your money on a corolla.
then spend the rest of your $7K or so on steroids, hit the gym, get fcuking massive and when any of your xr/clubadore mates says anything about your corolla, go nuts, rip their arms off, and beat them to death with them.
https://www.sau.com.au/forums/topic/108975-turbo-upgrade/#findComment-2007972
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
