Guys,
IF anyone has any information on a 1990-1992 red toyota corolla hatchback, wearing the number plate yap-84z tonight (which isnt the cars actual rego) please pass it onto me.
The car looked something like this,
http://www.carsales.com.au/pls/carsales/...0&year_max=1993
except totally standard, it had steel rims on it. There were 3 ethnic appearence looking blokes inside the car, about 6 foot tall. One wearing an army style top, another with black top, and jeans, and another with a pale blue top and a red hat. They were around bunda street in civic around 840pm, and were in manuka/kingston around 910pm. At 10pm they were back in civic, near ainslie at 10pm on limestone avenue. They proceeded to head to the tuggers, qbn way along the manaro highway. Any information that could be had on these people would be excellent.
Anyone who doesnt want to post the information here can do it via PM to myself.
Thankyou.
Dayne
stockies, bassically a complete stock old red corolla with a broken windscreen shouldnt be to hard for all of us to spot. link to canberra cruises http://www.canberracruises.com/forum/showthread.php?t=1260
Edited by eddie3330
By the other story...
Sounds like the broken window leads to a stolen car..
It most prob wont be out again.. All you can do is prob look for identities..
Have a funny feeling it might be the guys after my car.
i seriously hope these c**ts are found tonight man, no one has the right to do that shit. f**k thats gay, cant even drive around without some dumb f**k trying to be a big man by bashing someone half his age. thats f**ken bullshit and if you ask me its cowardly. hope those c**ts are found tonight...
P.S. if you need company for tonight gimme a buzz, you got my number.
i would take you up on the company but already got 3 ppl i think if not ill give you a buzz can u give me your # tanks man
Just saw a Corolla about the right age with faded red paint and a couple of middle eastern looking guys inside driving down Canberra Ave near St Eddies, heading towards Fyshwick/Qbn direction.
The driver was wearing something wierd on his head, looked like a towel! They were well past me when I realised what sort of car it was, so didn't see the windscreen, and only got a glimpse of the rear plate because there were bushes in the way, looked like YCP something.
Hopefully someone else will spot them driving and get a better look than I did from the footpath.....
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
