Hey guys got some parts for sale that didn't end up going in with the rest. All brand new in the box.
Nismo Engine mounts RB25DET (no hicas) 2 x front 1x rear SOLD
Tomei adjustable intake cam pulley RB25DET $150
Tomei Z32 airflow meter with adapter $350
Greddy clear cam cover RB26DETT SOLD
Bosch 044 fuel pump $300
Also have standard injectors RB25DET (SOLD), white r33 standard side mirrors, standard RB25DET intercooler, make an offer if interested. Parts are in tas but I live in melb so can arrange for pick up in either state or buyer pays postage.
pm on here, email at [email protected] or call or msg 0408570624
Cheers Paul
Edited by phat_r33
Nismo Engine mounts RB25DET (no hicas) 2 x front 1x rear $80 per piece or $200 for all 3
What's the deal with the "no hicas", does that only impact on the rear mount?
To be honest I'm not actually sure, just what it said when they arrived. Will endeavor to find out asap.
Cheers,
Paul
Whats the lowest on the afm you will go?
The price listed is what I am selling for. It is brand new with adapter plug. Didn't realise I already had one.
Hey mate! Are you willing to stretch to $150 for the mounts + shipping to Sydney? Please PM me your reply! Cheers!
PM sent
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
