Hey guys i recently traded in my 33gts and topped some money onto that to get myself an 89 r32 gtr ;)
Ive only owned it for a week or so but what are the normal problems that arise with these cars? Im aiming for reliability so any problem areas that i should be careful about? Also, i noticed when i drop gears it sounds like a backfiring system. Its like a pretty loud POP but it only happens sometimes. Can anyone enlighten me? This is my first turbo car btw so sorry in advance for these noob questions =P
Thanks
I would say best option...
1.) full service replacing all oils and fluids (engine, diff, gearbox, power steering, attessa, brakes, radiator, etc..), spark plugs, all filters (oil, fuel, air), timing belt, water pump, and probably other belts.
Clean injectors.
Compression test to make sure it is healthy.
Now that the car is Healthy.... buy and install these.
2.)new fuel pump, power fc, boost controller
3.) tune for safe tune, on our fuel, at something below 1 bar boost.
this should give you a decent power increase, and have a car which is safe and probably last for a long time if treated right.
I'd say the above would cost under $5K
guessing $2K on service and $3K for parts and tune
Popping sounds are usually unburnt fuel combusting on hot exhaust parts. Mine does it very occasionally. Apparently the stock ECUs run rather rich. Nothing to stress over though.
If you are after reliability and have the boost restrictor in, leave it there. As it's an 89 model you should overfill your oil by 1L. And remember not to flog the car until it is warm - most turbo failures occur when guys stomp the gas and the ceramic exhaust wheels are cold and shatter/disintegrate.
This has kept my 1989 RB26 working without a rebuild. And rev210 is spot on dude, adding power to an old motor must be done carefully.
im suprised noone has mentioned the oil pump. it is major, but it happens alot and is a top cause for rebuilds on these things.
ive seen more oil pumps on r32 gtr's go than tyres do on a commo at summernats.
best way to improve reliability is to sell it and buy something new with warrenty, that way you dont have to drive it everyday and hope it dont break down on you and cost you 6000 to rebuild. just my thoughts
sorry but i cant afford a newer car than this with around this sort of stock power T_T
im having hell at the moment just after buying it heh
thanks for all the replies guys but just wondering how much would it cost to replace the oil pumps?
my theory is that if its cheaper than changing the engine if the faulty oil pumps cause a major engine failure then its worth changing =P
Edited by nauzilus
Its not. Fixing the oil pump problem requires removal of the engine from the car, and removal of the crankshaft from the engine to press a collar on to the end of the crankshaft (which drives the oil pump). Engine R&R is ~$2000-$2500 depending who you use, and the crank collar work would come to about $1000 or a little bit more.
Other option is to chuck an R33/R34 GTR engine into the car which have this problem fixed.
If the oil pump fails while you are driving, you can expect to be up for a full rebuild. Unfortunately theres no way of telling how bad the problem is until you remove the engine from the car and take the oil pump off. It comes down to luck basically.
you dont need to remove the engine to change the oil pump.
you just need to take your radiator/condensor/fmic/front bar off as they tend to need a hydraulic puller to get their balancers off.
after thats off its a matter of removing your timing belt gear, dropping your sump, replacing the oil pump and putting it back together.
it would take a few hrs at the most to get it all done with the right tools.
it took me just over an hour to get my oil pump off (i dont have a front bar on my car), and that included taking my radiator and condensor out and dropping the sump.
As Duncan said, its basically an engine out job to change the pump on the GTR. Changing the pump doesnt fix the problem though, at the end of the day youre still going to have a short nose drive on the crank. The only real way to fix it is to pull the crank from the engine, grind the nose of the crank, press a new collar on and grub screw it in for good measure.
Pro Engines do this for a really good price, and use a JUN copy crank collar. Is basically identical to the JUN one, but a few hundred $$ cheaper. www.proengines.com.au
Justjap:
Have a look around JDM JustJap, SSS etc....
http://justjap.com/engines.htm
Omori Built RB26DETT -$9800
New GTR N1 Block -$3450
New GTR N1 Engine -$12500
GTR RB26DETT [used] -FROM $6500
i'd like to have that Omori Built RB26DETT -$9800
R34 N1 Turbos, Full Loom
With Harness & ECU
But befor it goes in get it looked over and make sure it's got stuff n1 water/oil pumps etc
what does omori built mean?
damn a brand new engine.. ;)
might be able to afford it after a yr of working part time at maccas.. lol
on top of the cost of the engine i should put aside how much roughly to get it fitted in?
damn a brand new engine.. :)
sorry dud i dont mean to offend you in any way, but after asking so many questions it seems to me like your not the kind of person that can maintain a gtr, its not as easy as everyone thinks, and working at maccas is a big no no if you wanna drive your gtr weekends esspecialy when things start going wrong. better sell it for what ever you can get for it and buy something more in your budget, maybe turbo excel or civic or anything else
ouch.. :P
everyone has to start somewhere man.. gimme a break. =.=
im sure not everyone has a cushy office job like maybe u do but ill do what i can
btw if i dont ask u guys here who are pros at skylines where else can i learn about this? :)
Omori is a tunning house back in the land of the rising sun... :P
Serriously- wait till your over 25 before you buy one of these things-
better/stable job
lower insurance
other intrests
for now just get some thing NA, cheep to run and insure: excell, mirage, lancer with evo kit, civic with vtec badge or kia with bonnet scoop, don’t stretch your self with a loan.
Labour is about $80 hour
I'd think it would be about 10 hours minium to pull out and put in an engine
Then plus another 5 hours for the initial dyno tune and many tunes after that to get it perfect
Just do a search on engine swaps and dyno tunes
Float round the forums for a while and do some back-reading
The answer is here- you just have to find the right posts! or try at Skylines down under...
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
