1993 R33 skyline. 100,050 km.Red Wine. Great car to drive and admire. Selling due to new job. Contact Roberto on 0421913340 for any additional information. The car is in Clayton on weekdays and in Kings Park on weekends (MELBOURNE, VICTORIA). $16500
-Adjustable suspension
-HKS Front Mount Intercooler
-Blitz Boost Controller
-Blitz Boost Guage
-Tomei Short Shift
-Bosch Fuel Pump
-Cusco Strut braces (front and rear)
-Xforce Exhaust
-Modified Cam gears
-POD filter (enclosed in heat shield)
-Cold air intake
-Tinted Windows
-Brass Button Clutch
-GTR Body Kit
-Kenwood Cd Player, Kenwood / Velocity Splits, Sony 12 inch Sub, Velocity Amp
-Turbo Timer
-New Tires
-17 inch Rims
-100,000km Service already completed
-Comes with original Body Kit, rims and HKS super sequential Blow off Valve
Edited by robertosr33
https://www.sau.com.au/forums/topic/109042-impressive-r33-for-sale-16500/
